Hyena
Technically I should post this in the non-hub motor forum I suppose
[youtube]b9QedZlRwvc[/youtube]
johnrobholmes said:That doesn't look dangerous at all! Great for clearing off pedestrian paths![]()
EVnewbie said:Now I have a use for my 3,800 RPM 48V 35 amp brushless motor and controller!
One larger fan (about 750mm across) gear the motor and propeller drive for most efficient speed and press on. Yeah, I would use a propeller guard for obvious reasons and it would be a simple drive train. No worries about overheating electric motors, spinning hub motors in the dropouts, gearing high speed motors way down and all those challenges.
Could I go 25 to 30 MPH with a single prop? Attach the rig to mountain bikes, recumbent bikes, row boats and the like.
Think the cops would notice?
AmpEater said:OK....so I want to do this (on a boat)
Does anyone know of a good motor and prop combination for pushing big stuff at relatively low speeds? Direct drive for simplicity. Just go with a monster turnigy and a 18" prop? Its got to be more complicated than that
I'm going to be putting it on a kayak. Solves to many problems....no holes below the water line, ~20lbs saved by ditching the trolling motor, virtually zero drag when off, and not limited by design to a low speed like most trolling motors either. Its so elegant to just bypass power transmission issues and just push against the air directly
I wonder if 5kw will get a kayak up on a plane?
Might suck if you top a hill and find the road curves quickly away, though, or it's a T-intersection with a high concertina fence.Whiplash said:I like the idea of having fixed wings for little glide sessions! Make the hill tops a LOT more fun!
