gwhy!
Whiplash said:OK guys, I guess I didn't make the question clear, how do I actually determine the degrees on the motor? Do you use a degree wheel mounted on the shaft, or do you just use a protractor and more or less guess at the correct alignment? It can be quite hard to figure degrees on a round object without a degree wheel or something...
Hi Whiplash,
How I done it was to draw a circle of the dia of the motor then divide the circle up Just like in the drawing in my previous post. There are no alignment issues because when the halls are mounted ( they are not fixed to the motor but to the mounting plate) they can be adjusted to give the correct alignment.
