scoobydrew
- Joined
- Nov 29, 2015
- Messages
- 17
Hi all,
I'm after a little advice please. I've built an ebike previously, based on an old mountain bike with a 500W rear wheel Q128 kit from BMS. This has been reliable although I have recently ruined the batteries by not looking after them - my own fault as I didn't disconnect them properly and over discharged the lipo's. So... time for new batteries and a new bike.
The bike will be used for commuting to and from work - this is all road, although with a reasonable 1.5mile long hill on the return journey. Total round trip is 20miles. Currently with the 500W Q128 I use approx 3500mah @ 48V lipo, although this is with fairly hard pedalling. The Q128 manages the hill without overheating at around a speed of 16mph and tops out with fresh batteries and frantic pedalling at probably 24mph.
I am looking to up the power level somewhat to reach a cruising speed of approx 30 - 35mph. I appreciate that at this speed, my pedalling input will be limited. I would like to build a good looking bike which still looks like a bike, without loads of batteries, wires and motors everywhere. It is also important that it is reliable. I can charge my bike at work as I can monitor the batteries constantly at my desk.
Budget is somewhat limited as I need to partially justify the outlay by making savings in fuel costs, so it will need to 'payback' if possible.
My thoughts so far are as follows:
Simple cruiser style bike (https://www.amazon.co.uk/Bermuda-Blackster-Cruiser-kickstand-mudguards/dp/B00XU7SP1Q/ref=pd_sim_sbs_200_4?ie=UTF8&psc=1&refRID=QYXR06MBFV2G5JK45HM8)
1500W DD rear wheel kit (http://www.ebay.co.uk/itm/LCD-48V1500W-Hi-Speed-Electric-Bicycle-E-Bike-Hub-Motor-Conversion-Kit-26-rear-/191859703745?hash=item2cabbabfc1:gvQAAOSwqfNXkVNa)
I would probably change the bars and seat to give it a more 'board track/vintage' look. The controller would be mounted in the frame triangle, probably in a frame bag (with plenty of ventilation holes). I've obviously given this some thought but would appreciate your input on the following:
Would the steel frame hold up to the task?
Any ideas on what the battery consumption would be like, moving from a Q128 500W to a 1500W?
I already have some 26x2.5" big apple tyres. Would a rigid frame and forks still be OK for street riding at the higher speed?
If front suspension would be best has anyone used this type of fork previously and if so, are they any good? (http://www.ebay.co.uk/itm/26-Classic-Straight-Spring-Fork-beach-cruiser-lowrider-bike-fork-153731-/282077461842?hash=item41ad207d52:g:dEgAAOSwDlBTweia)
Would it be necessary to upgrade the brakes? I would like the look of a hub brake on the front, which would also fit with the above fork if replaced. Braking would need to be good/effective but I will not be doing long decent's and overheating the brakes etc - just need to stop in an emergency. Low maintenance of a hub is also appealing.
Many thanks guys - as always, your thoughts and comments will be appreciated!
Cheers
Andy
Cheers
Andy
