TJP
10 µW
I would like to convert a new dual suspension Aluminum 27.5 Plus boost MTB frame with (2) 4 kg hub motors. The plus boost frame will allow the use of 3.0” wide tires.
How can I install a MAC/BMC/Ezee rear hub motor without cutting out the thru axel rear frame holes?
I found these 2 threads which show torque arms.
https://endless-sphere.com/forums/viewtopic.php?f=1&t=11570
https://endless-sphere.com/forums/viewtopic.php?f=2&t=26444
I understand how a slotted torque arm and a clamping torque arm are used.
How is the wheel and motor hub axel fitted through the round holes without spreading the rear triangle?
Thanks in advance for your help.
Hi speed, light weight, high strength dual suspension conversion
Max speed on level ground: 60 kph
Max range: 50km at 50 kph
Brakes: Hydraulic Disc
Terrain: 80% asphalt 10% gravel, 10% trail with moderate grades
Wheels: 26" X 39mm
Tires: 26” X 2.5” to 3.5”
Frame: 27.5” AL Plus Boost Full Suspension
Rear Hub: 4kg MAC, BMC or Ezee
Front Hub: 4kg Grin All axle or other Direct Drive
Max Bike Weight: 35kg, 77 pounds
Rider Weight: rider 75kg, 65kg passenger approximate 10% of time.
Wheels: 26" X 39mm
