safe said:
This project is interesting.
I think you missed a very valuable possibility on this in that you could have placed the legs within the protective cage and simply allowed the rider to pull them to the side when needed. (there's a tube in the way keeping the legs exposed as shown) If the legs were protected within a moncoque shell you could crash the shell and never have your skin touch the pavement. You could then strap the rider in very securely and be almost like an Indy Car on the inside. Ideally you might even make the feet drop down from above rather than sticking out the side. It's protection from the side in a crash that is important. (once you are up and running you don't need your legs for stability anymore)
The aerodynamics would be excellent!
I'm thinking that the "moment of inertia" is so low on these things that it's the best feature. Since it takes less to get the mass to rotate in the first place you have less to worry about in it getting away from you.
What feedback do you have on how it handled?
That was an experimental machine - never remotely intended to be reproduced as it is. I'll go through the flaws first!
The legs out the bottom/side was a mistake - you're right, they would be better out the top! The problem was putting my feet down and whacking my knees on the upper frame rails. That HURTS!!!
The steering control torque tube was waaay too flexible - it required a very steady hand to steer it. Once I got the hang of it, it was tolerable, but it still should be a lot stiffer. I never let anyone ride it - the fixes in the followup should take care of that. But it does roll in and out like nothing else - it feels weird at first, but the head gets used to it.
The seat is too upright, but I wanted to figure the steering out without having to deal with any learning curve my inner ear and different visual perspective might cause. The upright seat position helps there, but gets old fast.
The gas ones have been ridden by others - and all generated a lot of enthusiasm. One of the gas ones was taken to a scooter race about 1.5 years ago - and a lot of kids rode it and liked it a lot. But that race series ended - and so much for that. I've also done zero promotional work with them other than to expose them on the internet. In the mean time, the electrics have made some great strides in the last few years - I can build a much better light electric racer than a gas one for the same amount of work and money. No noise, no vibration, no smell, no problem!
The next one (I hope) won't look anything like the above picture. But here's what I'd love to do this spring:
Have the frame along the side of the rider.
Run a "bodysock" (stretchy full fairing) around the bike and rider for aerodynamics and maybe some added road rash protection. The fairing nose would still be plastic, but I'm wondering what the potential is for a kevlar/lycra/nylon fairing would be - it would be easy to get in and out of, easy (if not cheap) to replace, and easy to add graphics and such (hey, gotta have sponsors pay for my fun...)
Two wheel drive - easy to do with electrics. One thing low CG type bikes tend to do badly is transfer enough weight over the rear wheel while accelerating out of corners. Which is where 2WD comes in.....
It'll probably have normal handlebar type steering - the stick works great but takes a long time to adapt to.
Etc...... Gotta build something - I'd hate to see the next one not get past the "hot air" stage of the project! Most importantly, it would be great to get some feedback on it.
