Hi guys,
I'm currently working on an electric motorcycle prototype for my final year uni project. My frame is well on it's way and I have nearly all the components I need to put together the electrical and drive side of things. I'll run you through what I have and what I'm planning for the electrics, because I'm really not sure if it's correct or the safest way to do it.
Motor - Motenergy me0909
Controller - Alltrax 4834
Battery - LiFePO4, 48v, 20AH with BMS
Magura throttle 0-5k ohm
Battery kill switch - 300A
Fuse - 300A
I found a wiring diagram online and modified it with the set up I currently have.
As this is a proof of concept motorcycle with a custom made frame I won't even be thinking of trying to register it, so having a proper ignition switch and working accessories aren't a major problem. With the current set up I would plan to use the kill switch as the ignition switch.
One question I have is; do I need a contactor with the precharge resistor and diode? I've seen this set up a lot and I'm wondering if I need it, or if it would greatly increase the safety of my components?
Something like this
Thanks
Fuse - 300A
Something like this
Thanks
