Today, after a lot of rest yesterday (after getting the TNG Transporter Console ready for Coppercon, delivering it and the classic console to the con and setting them up) and the first half of today, I finally felt well enough to get some work done on the bike. Fortunately my crazy sister hasn't been home most of the day, so I could work in relative peace (there's still the dogs, but at least I can predict what they'll do and work around it).
First thing I did was to rebuild the 36V 13Ah NiMH pack plus the 12V 13Ah into two 24V 13Ah packs I can run in series. The 48V ought to make enough of an oomph difference to help make up for the voltage sag it has under current loads approaching even 1/2C.
THe white plastic strips used to be clipstrips holding products to shelves in a store, for impulse buys.
They're very thick and slick plastic, so they will keep anything from shorting the ends of the cells together. I already successfully used them on the pack as a 36V pack since I put it together after arrival from Ianmcnally. A couple months, I guess?
The fan in one of hte chargers was dead so I swapped it out from some stuff I had laying around saved from some other dead device.
That red pencil iron is an 80W Weller, 900F. It'll solder 10G wire to the end of a NiMH F-cell in about 3 seconds.
1.5 seconds or less to solder nickel tabs.... It was a gift from a local friend, picked up at a closing-down Ace hardware (he also got me some more dayglo paint).
I swapped the XLR connectors on the chargers for Powerpoles...I also changed all the power connections on the Lyen controller, the Fusin headlight/powermeter/keyswitch unit, and the batteries and chargers over to the small 30A Anderson Powerpoles. I chose those because I have accumulated enough of them off of various things, plus a few new ones, to be able to put them on all the things I want to use on this bike. I don't have enough of the large 50/60A Multipoles to do this with, even if I take all the ones off of CrazyBike2, which I'd rather not do. That bike *needs* the hefty power connectors, and DGA doesn't, really, with the current limit of 16A (20A in reality) I've got programmed into the Lyen 6FET right now.
I also put them on the now-repaired Turnigy Watt Meter
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=21267&start=0
but I left the Multipoles on the WattsUP from AussieJester, so I can use it on CrazyBike2 or The Velcro Eclipse (both of which still have Multipoles for battery and controller).
It might be hard to see in the pic above, but I put the thermistor on a blue powerpole on the packs, and a yellow one on the chargers. This is so I get used to the idea that blue doesn't plug into blue, so I don't get tired and forget not to hook up the thermistors together or try to plug the packs into each other. :lol: I put the powerpoles in an L shape so I can't plug them in off one row or something; I'm probably going to stick one more in there as a key that's different between the two so they can't be plugged into each other even accidentally. Because that would be very bad.
They are to be run in series, which means that at the moment I have to unmount one of the red or black powerpoles so that it can be plugged into it's opposite on the other pack. Then the keyswitch cable on the Fusin headlight/etc unit gets plugged into the remaining + and - of the seriesed packs.
Since the Fusin headlight unit is for 36V, and I do not have time to investigate it's innards to either verify it can be run right off 48V, or to alter it to do so, I just clipped the wire from power to the board inside it. The keyswitch still works, just no headlight or power meter on it for now.
I didn't have time tonight, but at some point will put powerpoles at the output of the Fusin H/KS/PM unit so I can plug a watt meter right after the keyswitch, without running another long set of cables up the frame. I will also move the controller up there on the bars (stem, actually), both so it will get better cooling and so that I can shorten all the power wiring to only *one* long run up the frame, isntead of two. That'll also shorten the motor wires and all the bar control wires, too.
Took it for a test run around the block, and it absolutely performed better than as a 36V pack, with the sag. Unfortunately I was stupid and shutoff the keyswithc like always before getting off the bike, which cleared the wattmeter readings.
So I don't know what the minimum voltage was, alhtough I know it was 56.02V starting out.
I recharged the packs, each with it's own 24V 3A charger, with a desk fan blowing on them to keep them from staying hot very long. Charge was successful, after about an hour, so about 3Ah of power back into them. I did not use the wattmeter like I should have becuase I don't have two with the right connectors yet, and somehow didn't think of monitoring just one (since the other ought to be similar).
I'd like to charge them in series, but I don't know if the chargers will work right that way, due to the thermistor being referenced to pack negative--it might damage something to have a 24V+ difference between the thermistor ground on the "top" pack and the actual pack negative. So they each get their own charger for now, or I can charge both with one charger, just one at a time.
Theoretically the 48V pack as 2x 24V should charge faster with two 24V 3A chargers than a 36V pack with one 36V 4A charger.
It'll be a busy and tiring week again, so I doubt I'll get much done unless my crazy sister stays out of the house, so I can do things outside my bedroom without encountering her and having to deal with her and the problems she creates.
