They do! :lol: The first week's mileage should pay for all the dog food I have been buying up on clearance the last month or so, whcih itself should last me several months. The second week's mileage should pay for whatever clearance dog food I manage to get from *this* store's remodel sales.
Buuut...I am probably gonna need to buy some new tires and tubes soon. Remember Crazybike2's sidewall/bead separation? Well, I had something similar today, on the way home, on Delta Tripper.
The front 20" tire, which has that airless tube in it, has been feeling squishier and squishier, for no reason I could figure out. Today, an odd noise began, but I couldn't figure out which wheel it was coming from--it was obviously a wheel, from it's changing repetition rate with my speed, but it sounded like one of the back tires or even the trailer--yet it was the front.
About halfway home, just after I crossed over from the north to the center path of Thunderbird Paseo park's canal paths, the front wheel got wigglier than usual, as if I'd broken a bunch of spokes--but when I looked, I coudl see nothing wrong. I manually rolled the wheel on the ground and could *hear* a squishy patch and a bump, but couldn't tell what it was, and seeing as I didn't have a spare (who needs a spare for what amounts to a solid tire? ), I just slowed to 10MPH and went on.
But it got worse, and worse, and worse, over a few hundred yards, until I could SEE the tire looking like it was coming off the rim.
I stopped, and got off and looked at the wheel, finding the bead popped out of the rim and the wire of the bead actually coming out of the tire rubber and weave. Great...still almost 6 miles from home (though almost all canal path). I thought maybe if I just crawled the trike at walking speed....nope--the "tube" was getting squished out the side, and was just gonna com eoff the rim, and probably land me and the trike and trailer in the canal or worse.
So I sat there, parked in teh shade of one of the big power transmission poles along the path, in the gravel off to the side of the paved path. A couple of minutes later, I realized I DO carry a spare with me!
In fact, I carry TWO spares--on the trailer wheels! :lol:
Since I had almost no load on the trailer, just a frame off the bottom of our old book rack and some of the top support frame for it, I coudl take a tire and tube off of the trailer wheel, and swap for the one on the trike's front wheel! Genius? No, more like Captain Obvious.
Given how tired (ha!) I already was, and how much I hurt from all the climbing around and lifting/moving stuff I've been having to do at work for the remodel, it took only an hour or so, maybe a little more, to swap the tires/tubes.
EDIT: forgot to add that while takign the airless tube/tire off the front, I found teh rim tape (really a rubber strip) wadded up in the tire. That was the bump, and it might have been the whole cause of the failure, bead unseating, etc--if the scrubbing of the hweel from angling steering to compensate for the motor power on teh right wheel caused the compression/decompression of the airless foam tube to wiggle the rim tape up and out of the rim and then begin stretching/rubbing it on the sidewall or tread area inside the tire, it could've ended up wadde dup like that, in teh sidewall, pushing it out more and more with each tire revolution....until plop the bead pomes out. Not sur what actally causetd t bt wanted to note this beoefore i doze off againa tnd forget.
I coudln't seat the bad tire fully on the trailer wheel's rim--it just was too damage and distorted to fit correctly anymore. I put it on as best I could, and faced it so if it did come off it'd be to the outside, and not get tangled up in the trailer and cause it to lock up and do something bad, like maybe cartwheel or flip or drag or whatever, and cause me to crash. I'd rather just have a sudden loss of the whole tube/tire off the rim, which would be wierd to pull, harder to pull, but wouldn't be disastrous.
The trailer tire/tube worked just fine at about 45PSI on the trike--it actually handles way way better now, but I would dread what might happen if the front tire blew, and it only has a bit of slime in there, in a thin tube. So I kept it down to 15MPH or less the whole rest of the way.
The airless tube/tire on the trailer wheel didn't cause any issues, but I could hear it thumping around back there sometimes, though it never had enough weigth on it to push the "tube" out of the small opening in the tire seating. It cmae only slightly more unseated on the tirp home than it was when I started out, jus undert 6 miles before.
I have been sitting here dozing/waking/reading/typing just like most previous evenings for a while, writing mroe each time I wake up. I want to go work on CrazyBik2es wheelmotor promgbelm, but i dunno that I can concentrate well enough to do it, long enough to get it donwe. I go tup yesterday to do it lke I said above, but that dnitn'a work out very well. I had the old controlelr in my hands, and turned on the sodlering station, was just gonna cut the hall wires again on the motor and splice to this contolrller, but dozed off and woke to the dogs in my face a bit later. Decided I wasnt' competent to do the work and quit, went to bed. (wake/sleep/wake/read/sleep/etc.)
Probably end up the same tonight.
But I will carry a spare tire and tube fro the trike with me tomorrow if I don't get CB2 fixed in time to really test it out.
Oh...and this is the frame I was talkinga bout above, from the book rack. I am thinking it'd be a good trailer frame. Muhcb etter idea than the folding table conversion.
In fact, the tubing is the same size as the present trailer's, so I could pretty easily take all the bits off teh trailer frame (tow hitch arm, wheels, etc) and put them on this one instead, to get a longer trailer. Just need a platform for the top,a dn I have a number of things that would work, including more plywood. I would also probably put a short "fence" around the edge of the trailer to hold in loose stuff that cant be as easily tied down as long bits. Maybe one that can be removed with a quickrelase of some type so I can stll use it for longer stuff than the trailer is. (like that table)
Maybe even make it a four-wheeled trailer, with the pairs of wheels close to each other in the middle like car-type trailers sometimes are, for heavier loads and redundancy of tires. I have two sets of bolt-on wheels with one-ended axles, in 20", from those jogging strollers. Hmmm.... (wish I had time/energy to go play with the idea right now while I'm thinking about it).
