Hummina Shadeeba
what sizes are you using for how many amps?
https://www.rcgroups.com/forums/showatt.php?attachmentid=1214696&d=1173563160
dustNbone said:Aluminum doesn't take repeated bending well,
All in all I don't think it's suitable for anything subject to movement or shock/vibration. .
Punx0r said:Aluminium is used for transmission lines because it is more conductive per unit weight than copper. In all other respects it's inferior in performance to copper and notoriouslyy unreliable in domestic wiring.
Hummina Shadeeba said:anyone have the formula on hand or in head for figuring the wattage lost to heat in a wire? copper preferably. based on wire resistance, length, and amps is all I think.
Hummina Shadeeba said:what sizes are you using for how many amps?
Hummina Shadeeba said:Matador Looking at the chart cross-sectional area doesn't parallel ampacity: the 5mm x
.1 is rated at 48 amps and the 10mm x .1 is 66. What's going on?
Ampacity is defined as the maximum amount of electric current a conductor or device can carry before sustaining immediate or progressive deterioration.
