Approximate cost of materials to build a basic chromoly MTB bike frame?
Hey Nep, if it means anything to you I was in a semi similar position about 12-18months ago after my BikeE AT suspension failed for the 2nd time.
Not wanting to continue paying others to weld it, I decided to investigate learning/doing myself.
In the end, what tipped me over the edge was discovering the newer welders that are 'automatic' with settings etc. i.e. you tell it what you are doing and it sets up everything for you. Obviously you can then tweak things as needed, but it's a far easier starting point.
I ended up going with the Cigweld 185 ultra for around $1500AUD. Not cheap, but Stick/MIG/TIG capable and from a reputable/reliable brand.
Since then it's proven extremely useful and I've build all sorts of awesome things from a trailer cage to, fire pokers, and repaired tons like an Escooter and ironing board just earlier this week.
I still haven't made any bike frames, but I'm slowly collecting metal, old bikes and just trying to get better at welding with other things. Eventually I'll give it a crack!
I would say, just jump in a get something and start playing around (safely). You'll be surprised how useful a welder can be!
Cheers
1/16 inches is 1.5mm and the thickest metal i need to join is 2mm ( headtube ).
It sounds like i need something bigger.
What do i need to weld up to 2.25mm thick chromoly?
Tip supplied in the kit is not large enough. All that's need larger tip. Small tanks will drain faster but otherwise a larger tank is not needed.
Oxy Propane flame temp is 5,100F
Oxy Acetylene is 6,000F
Propane does work.
Acetylene works better.
They tend to offer two types of "welding classes". One is for artistic for people interesting in metal sculpture. The others type would be tradesmen that want to obtain certifications for employment. The artistic ones are a complete waste of time.
Yea... I did a gig in a Community College environment.
Yeah. I'm surprised at how much TIG welder you can get for the buck these days. I like that they can be more forgiving; i would think that would reduce the steep learning curve for TIG.
Omg i can't wait until i can do that. That sounds like a ton of fun.
Recumbents next? :)
Cheers
Thanks for your words of motivation!
Sorry 'bout the OT Chief...
Honestly i'm kind of loving those showoff posts, gets the gears spinning in my mind!
I'm fixated on that recumbent design you posted. It's super inspiring!
OT appreciated in this case :)
Another "show off" picture . . .
This was made in high school metal shop shortly after the "Easy Racer" movie came out in 1969 ~ 55 years ago.
Welding school in those days was either Oxy/Acetylene or stick, no MIG or TIG.
My teacher was so enamored with it he entered it in several fairs where it earned a third place ribbon at each showing.
did you ever start the project?
keep in mind that it's not hard to build something, either braze or weld processes...it might be harder to make it look nice (never been able to do that). my stuff including the heavy-duty cargo bike and trike were built by welding together wahtever steel (junk or good bike tubes) with a crappy harbor freight wirefeed welder. the welds don't fail, though the material itself does because of design flaws in my frames and/or because of defects in the materials used (most was never intended to be used beyond holding up big plastic or paper signs inside a store :lol: ).
so it's easily possible to do it with minimal investment...but you will get better results with better equipment and materials.
if i could have afforded it, and been able to do the precision fitment required (i don't have sufficient body control, really) then i would probably have gone with brazing instead of welding.
(though having the welder has let me fix things i don't think i could have brazed very well, like my fences, etc)
No. I was interested in what the feasability is to build yourself. It's pretty good; ~$1000 in tools and materials and i can build my first bike.
I just need a location where i could build such a thing, see ya in 2-3 years, hehe..
In the meantime, i can get a custom upright frame really cheap from Peru. I've thought about getting a 29er hardtail frame with a + 1.5 inch chainstay ( versus what's normal ) and slacker seat tube angle built.
Custom Built Steel Hardtail MTB Frame - MarinoBike
This company has good reviews and would be a better hardtail builder than me.
It's the recumbent designs i want to work on that require a lot of space + trials/tribulations... down the road, i think!
Howdy, i searched the 'net already for a bit and could not find information on this.
I see that on a site like this: https://framebuildersupply.com/collections/main-tubes
Nice site.
I like how they have the motor cabinet for the 2016 and newer Shimano mid drive motor:
Too bad they also don't have lugged BB for double oversized tubes as well as the large diameter shell for the Bushnell eccentric BB.
Ooh, now folks can get a handmade custom e-bike that Shimano will abandon and leave high and dry whenever they want. Awesome.
