I am answering because I also went to verify this. It is the OpenSource free KiCADElectronS said:Hi
Great work ,
just a random question, what is the software you are using for designing the pcb , it looks awesome in 3D , much better than ALtium Designer 2016
Exactly,casainho said:I am answering because I also went to verify this. It is the OpenSource free KiCADElectronS said:Hi
Great work ,
just a random question, what is the software you are using for designing the pcb , it looks awesome in 3D , much better than ALtium Designer 2016![]()
I've seen better than a lcd displayimplemented Display support as a Dashboard
How easy would it be for you to implement the possibility of charging the battery via a coil and phase wire like adaptto does it.
Cause than its a real alternative.
Its based on VESC 6, supported by the latest vesc tool software.does your design actually base on VESC6 or VESC4 ?
marcos said:I didnt know about their charging scheme, thanks for pointing me at it. IMO this controller would go in bigger systems with big batteries that you want to charge safely.
With this in theory its possible to charge the traction pack connecting 3 phase mains directly to the phase putputs of this controller. Here that would be 50hz 380v, which generates 500v dc. Charging at 10, 50 or 100kw its just a variable in the firmware, pretty much the regen variable.
However, that would be a non-isolated charging, your traction pack would be connected to mains and its not safe. I guess its not legal either.
Yes, its a boost converter. Its neat for a small battery, not so much for a big one, but yes, its doable with some custom firmware. Just don't count on using a dc charging station, they will measure isolation between the battery and chasis and probably expect an actual battery instead of a switching power supply input. Also you need to comply to a charging protocol before it sends you any power.notger said:for charging an adaptto you still need any kind of DC source with lower voltage than the Battery is and a charging coil. (so i guess the controller acts like a kind of boost-converter )
but the amazing thing is you could charge it on DC-Charging Stations, any PSU, or even Truck or Car batteries.
Adaptto also offers Balanced charging with an external BMS-PCB
marcos said:Do you have gate drivers made for your IGBT modules or are you planning on designing your own gate drivers?
If you have to make your own gate drivers you can probably connect those boards directly to the controller if you use the correct pinout.
PM sent!Assembled spares from the company might be interesting if they do exist and are functional.
marcos said:Those murata are a good fit. You can calculate the gate driver power requirements from the igbt parameters, I dont know which switch are you planning to use, I used this quick math
https://docs.google.com/spreadsheets/d/1RqU3JVtsz6bLQ-Jg3h8EidA6YTpCaA3D6J5x7j_Y-Wc/edit?usp=sharing
