jmwhite151
I just received a Bafang CST motor from BMS Battery. I bought the 500W, 270 RPM motor: https://bmsbattery.com/ebike-kit/589-bafang-36v-cst-rear-driving-e-bike-motor-wheel-ebike-kit.html
On the motor, it says:
CST 36V500W 26
1506 7052-6
Is there any way to confirm that this is the 270 RPM motor? I've seen a list of motor codes (https://endless-sphere.com/forums/viewtopic.php?f=2&t=43106 and other places). But I haven't been able to find where the code is listed in the above numbers.
UPDATE: I just did a quick test. I was getting a no load speed of 38.3 MPH (using a wheel circumference of 2300 mm programmed into the cycle computer) at a battery voltage of 53.5 V. If I did everything correctly, that corresponds to 446.65 RPM @ 53.5 V or 8.35 RPM/V or 300.5 RPM @ 36 V. That seems to check out. It's a little higher than 270 RPM, but I think I read that the 270 RPM is actually a little faster than 270 RPM. Looking forward to getting it on the road to see how it performs...
Jeff
CST 36V500W 26
1506 7052-6
Jeff
