Bafang GO62 60v controller
Ebike92119
🔌 New-ish
Hello,
I was thinking about getting the Bafang GO62 hub, but the bafang hubs have proprietary connections, so I don’t think I can hook up a sabvaton or a higher volt controller. The kit I’m looking at is rated for 48v, but I’d like to put 60v on it. If I was good at wiring I could possible splice the wires and solder them to a different controller, but seems out of my abilities. Does anyone have any experience with that hub and the connections or any higher end controllers that would work for that hub?
Thanks.
BAFANG 48V 1000W Rear Hub Motor : 26 Inch Fat Tire Electric Bike Conversion Kit with Battery (Optional) for Rear Cassette Wheel with LCD Display & PAS https://a.co/d/aFM2MEt
The latest update for the sabvoton controller is they have started to use the tf4 cable with waterproof higo connectors that Bafang also use. I'm not sure if the pin configuration is the same but at a quess I'd say yes they are because the tf4 cable is as close to a standard the diy community has..
It might be worth contacting mcqon ( sabvoton) and asking them for the wiring diagram, they're usually really good at supplying that information
https://www.aliexpress.com/item/3256803618853324.html
you can get a wire this like and connect it to any controller,
