Looking for ways to make a weight weenie bafang motor. Thoughts? Here's what I got so far:
Going sensorless would eliminate hall cables and they can be removed from inside the motor. I bet that would more then make up for the sensorless module's weight.
Motor phase lead length could perhaps be reduced a few cms by making them exit inside the frame kinda like Link did(?)
New spoke holes for normal quality spokes could be made in the flange with drillium installed where the oversized spoke holes are. The inside of the outer shell could perhaps be bored out.
Freewheel seems to be made out of thick heavy stuff, dunno what it looks like inside but I bet there's quite a bit of excess material here. Anyone have a pic of the freewheel taken apart?
Motor cog plate that screws onto the magnet basket looks like it could use quite a bit of drillium as well.
Axles are a few cm too long for nothing so they could be shortened, also the side without a wire coming out could be hollowed. Kinda like the guy on this forum that turned a 4X clyte into quick release.
Not sure what could be done with laminations, I know most of the weight is probably there.
Magnet holding basket looks like it could use some drillium as well, in the spokes, near the centre where the cog goes, and on either side near the magnets the metal goes further then it needs to. Special attention to good balance here since it seems fairly heavy and spins ~5X wheel speed.
If they can be found, the screws could be replaced with Ti ones. Ti axle nut?
Any guess how much it would cost having this machining done by a shop? I'm guessing about the same as motor purchase cost?
