I would like to ask active Ultra drivers about reliability of the G510. I use it for commuting 50km per (dry) day, almost all the time with maximum possible power. Total km so far only 800km. Battery is a 52V 19Ah china pack, controller is the Phaserunner. The combination gives a lot of power, but after maybe 5 minutes of full power, the thermal sensor shows overheating and the Phaserunner chokes the power output down to something between 200 and 300W. When I changed the settings for temperature warning to higher values, the motor started to stink that typical smell when isolation materials are going to burn soon. So I kept a max temp of 110C°. It makes no difference if I have field weakening enabled or not. Now I always have to keep the power output down to around 700-800W, otherwise the Ultra will overheat very fast- full throttle is done only occasionally to climb high hills or get into the trafic flow fast. This is annoying.
I am the only one with that thermal troubles? I already milled vents in the left lid of the motor, it made a difference of maybe 5C°. Now I bought parts to build an active ventilation system including alum bent tubes, blowing fan etc, but I don't want no Steam-Punk-Terminator-Look for my bike!
Another thing: I'm quite sure that the Ultra is getting louder and louder on the mechanical side. Did anyone take one apart and measured bearing plays and gear wheels or found other wear?
Thanks,
elias
Thanks,
elias
