Hi All,
I am trying to work out a basic on off power situation for my bike (running 3220 and CC HV120 esc so pulling about 120 amps give or take).
Now forgive me as I am more a cut and weld kind of guy than an electron flowing guru.
As I understand it, using something like a boat or car battery kill switch will work in principle as an on/off switch but without a resistor to pre charge the esc capacitors will still cause an arc, prematurely eroding the connectors.
I think I understand that a 5ohm or so resistor across the terminals will prevent the spark by pre charging the esc but if it is just a permanent connection will see a small power drain on the batteries over time.
So my question becomes:
Can I use the key ignition switch I have as a first stage switch to connect the resistor circuit and then turn the big bad boy isolator switch to release the Kraken? A two stage starting process if you will...1) key switch for pre charge circuit with the resistor and then a second or two later 2) Big red isolator on?
Thanks in advance,
Ham
Thanks in advance,
Ham
