DanGT86
I'm wanting to use a 100-200 amp rated switch/circuit breaker on my battery box. I would also use a precharge resistor in parallel with the switch. The idea would be to connect the pack, allow the controller caps to pre-charge for a few seconds, then flip the switch. A breaker would be a nice additional safety feature. The cheap marine switch/breakers I'm finding are rated at 48v max. Ive been using a pre-charge loop in my wiring but its sloppy looking and annoying to explain to people. I'd rather just have one clean xt-90 connection and a switch.
So im wondering if i can use 48v rated parts at 84v (20s lipo) since they will not be switched under load. The pre-charge resistor brings the system to 66-70v before I make the main connection so the switch is only seeing <20v when the connection is made right? Isnt the drawback to low voltage switches the sparking at the contacts? Is there some drawback to the low rating once the switch is closed?
Something like this.
Or this
Or this
