Another thought on measuring batteries. If you have one of those little inverters (or know someone who does) with a low voltage disconnect, do this:
Plug in a lightbulb (variable load, even!) and an old school analog clock, and turn it on on. The LVD is repeatable, and so will always disconnect at the same voltage. Even if you don't have an ammeter, it's all relative. For big batteries (e.g., 50 Ah) , I use a 500 W halogen light - that's a 42A peak, 26A rms load. Smaller batteries, smaller bulb.
Anyway, set the clock to 12:00 (or something), and you don't even have to be there. Just return not too long after it shuts down, and recharge the battery. The clock will tell you exactly how long it ran under constant load.
I use this technique all the time. Very useful when evaluating batteries after desulphation, unknown batts, etc. Super easy, very repeatable, simple to vary the load. You do need the inverter, but those have many uses, and can be easy to borrow.
The CBA is also an excellent tool. But it's limited to 100 W (continuous), requires a PC, costs $100 ($600 for the 500 W expansion). If you need to balance $5000 worth of lithium, a great investment. But for less than $100, you also get an inverter you can use in your car (I know, but I bet most of us have one) to charge and/or run stuff. I use mine when camping - screw those propane or gas lanterns - run a CFL. Backpacking run LEDs.
Thoughts?
