how about what amount of time was spent at what rate of discharge (AND charge, be it charger, or regen). small equalizer graph kinda thing. could be mined a lot of different ways. total wattage used. expected deterioration, and the resulting cycle life. an order of magnitude more accurate volt meter might give you good data about efficiency, capacity, AND health. could also be useful in realizing a cell was going bad BEFORE it went bad, and then you figure out a way to limit drain of that cell earlier on. i mean, theoretically, you want all the cells to reach the LVC at the same time, right ? so is there a way to proportionally limit current ? using the BMS ? methinks so. like something proportional to sag, or it's deviation from the mean. or is it more like a weak link kinda thing ? would it be possible to just have an effect similar to limiting the throttle instead ? so that instead of pwm, you just have an upper level, dropping off, as individual cells kicked off ? you'd have reduced power, but at least you'd have power. and it seems like you wouldn't be pushing any cell past it's limit. ok, maybe sleep deprivation is making me loopy. anyways, love the bluetooth, and the real screen thing. justin needs to take the CA to that level, for $125. and the datalogger should be integrated into it. and a fixed memory and bluetooth might not be too much more, versus SD slot and removeable card. bit more weatherproof, too.
