BBS02 loud noise once per pinion rotation
hias9
Regular
Today I ran my BBS02 the first time.
Unfortunately it has a loud noise once per pinion rotation. Video below.
I think the nylon gear is on the same shaft as the pinion, so it is also once per nylon gear rotation.
The motor is new, just regreased.
Video: Watch V_20240229_232626_ES3 | Streamable
When pedaling faster than the motor is turning the noise disappears.
Does anybody know what is causing this noise?
Could it be the freewheel inside the nylon gear?
No, it was something different. As mentioned before, once per Nylon gear rotation.
I just uploaded it here again:
In the meantime I replaced the Nylon gear (although motor was completely new) which helped a lot and then I additionally installed a 0.2mm washer to reduce axial play of the Nylon gear which also helped.
Tkx for the reply I also have solved mine replacing the magnetic ring (maybe a simple cleaning would suffice)
