episani
100 µW
- Joined
- Jul 20, 2020
- Messages
- 9
Hi,
I'm sorry if this has been asked before.
The problem started a few months ago after hitting a bump, the motor would switch off. To fix the problem I had to switch the battery off, then back on and the bike kept going.
Now I has stopped working completely. When I switch the bike on it goes for a few seconds and then it switches off.
I checked the display for errors, and it has two errors: error 21 and error 30.
According to the documentation, error 21 is related to the speed sensor and error 30 seems to be a communication error between the display and the controller, which is usually related to bad connections between the display and the controller.
I checked all the cables and connections and they seem ok. The speed sensor seems ok too and it shows the speed on the display.
To rule out the display, I connected the programming cable. The error persisted. I switch the battery on, and the throttle switches the motor on, for 10 seconds.
Trying to get more information I installed the open source firmware for the controller, as explained here: BBS-FW: Open Source Firmware for BBSHD/BBS02 Controller
The error persisted, the motor stops working after 10 seconds or so.
With the open source config tool, I can see this error: Motor controller status changed to 0x100.
Looking into the source code downloaded from GitHub - danielnilsson9/bbs-fw: Open source firmware for multiple electric bike motor controllers. I don't have any clues on what's going on.
I'm about to get a new controller as I'm guessing the controller is faulty, but I don't want to spend money in something that might not be the cause of the problem.
Has anyone experienced a similar problem?
Thanking you in advance for your help.
