Jason27
Electro-Fox said:So guys....why does an AllCell battery cost so much?![]()
Superior quality, excellent customer service. Kinda like the Mercedes Benz of ebike batteries.
Best all-round chemistry, yes, in my opinion. Its been around for awhile, there are a lot of good manufacturers, its relatively one of the safer chemistries to use, has good cycle-life, and is recyclable and environmentally friendly, comparatively. A123 has the patents for nano-phosphate LiFePO4 and remains in a class by itself. I got my cells and kit to make them into a 16S 48V battery pack from OSNPower. I'd trust OSNPower, EM3ev, Ping, and BMSBattery for a battery. Also Headway and there are a lot of suppliers for that brand. Headway also relatively easy to get cells and kit to make up into a battery. You also need to consider, in addition to voltage, the amperage you're running.Electro-Fox said:This will be used with a Falcoe 500 watt hub motor, which uses an internal controller. I can use a 36 or 48 volt but thought that the 48 volt would be the best choice. Isn't LiPo4 the best chemistry?
You just need to work it out for yourself this one time. You've got a great hub motor in the Falco. Hang in there. And believe me that people who buy a ready-to-ride eBike like Pedego, also have to face the battery question when their first battery fails.Electro-Fox said:Well I am still confused and am thinking of throwing in the towel. ....maybe this electric stuff is not for me? I guess that is why people just buy an electric bike, instead of making over their bike.
arkmundi said:Best all-round chemistry, yes, in my opinion. Its been around for awhile, there are a lot of good manufacturers, its relatively one of the safer chemistries to use, has good cycle-life, and is recyclable and environmentally friendly, comparatively. A123 has the patents for nano-phosphate LiFePO4 and remains in a class by itself. I got my cells and kit to make them into a 16S 48V battery pack from OSNPower. I'd trust OSNPower, EM3ev, Ping, and BMSBattery for a battery. Also Headway and there are a lot of suppliers for that brand. Headway also relatively easy to get cells and kit to make up into a battery. You also need to consider, in addition to voltage, the amperage you're running.Electro-Fox said:This will be used with a Falcoe 500 watt hub motor, which uses an internal controller. I can use a 36 or 48 volt but thought that the 48 volt would be the best choice. Isn't LiPo4 the best chemistry?
Understandable. I encourage research and making an informed purchase from a reputable supplier. This forum site is the best place for that research. You'll encounter opinion as well as fact. So take some time and do that research, here and using Google search. As far as terms are concerned, https://en.wikipedia.org to explore that. For instance... https://en.wikipedia.org/wiki/A123_SystemsElectro-Fox said:They all assume that I know their jargon, but it is overwhelming trying to figure out each company. Then some give measurements while others don't, some provide pricing while others don't. OMG I cannot afford to blindly plunk $500 to $1000 dollars down without understanding.
Yes, you could do that. I mount my battery pannier style on a back-rack.Electro-Fox said:I notice that Ping (in some cases) gets the capacity by using two batteries...such as this one.
http://www.pingbattery.com/servlet/the-2/lifepo4-lithium-ion-phosphate/Detail
Could I get that and put them in a pair of panniers? One battery on each side? I can get saddlebag panniers or have them made. Then I would need to have the batteries protected in the panniers in case of a crash, but it would eliminate the lack of space problem.
slacker said:why dont you get a battery from falco ?
No. He was sourcing his cells from the Korean factory until uncertainty about the future of A123 arose. He's using top-of-the line Samsung cells now:eTrike said:CellMan still do A123s?
But it does beg the question by "what is best?" A credible vendor like Paul will say something about long-life, consistency, availability, etc. He wants his customers to be happy. His reputation matters. But they are not LiFePO4 which was the question.http://em3ev.com said:We now offer 4 type of Samsung cell in our packs. We have the ICR18650-22 (NCM cell, 3C rated, approximately 2.1Ah) cell. We also have the High Energy density INR18650-29E (NCA Cell, 2C Max rated cell, with approx 2.8Ah nominal Capacity). There are also 2 High Power cell, the INR18650-20R and the INR18650-25R. These are NCA type cell, 10C (20R) and 8C (25R) rated cells with Capacities of approximately 1.90Ah (20R) and 2.45Ah (25R).
Went hunting forslacker said:falco makes a rear rack batt also.
Panasonic NCR cells are noteworthy. But not LiFePO4, which was the question.Technical Specs: The pack merely weighs 2.5 kg and it delivers 417Wh of energy (36V, 11.6Ah). The pack has a number of primary as well as secondary protections. The packs use Lithium Ion Rechargeable battery cells from Panasonic (Cell Model NCR18650PD). Typical cell capacity is 2880mAh and minimum cell capacity is 2730mAh. The packs uses 10S4p configuration.... http://www.utahtrikes.com/PROD-11619093.html
Go for it! Cellman makes great battery packs, and as a vendor is highly regarded. He used to make his packs from A123 cells, back before the company declared bankruptcy. He has since made packs with top-of-the-line Samsung cells. You won't find a better right-sized battery-pack for sell. Its also an advantage to get everything from one vendor if you can. My setup was supplied by Cellman except for the battery. There is only one battery-pack that might qualify as superior and its a pack made from A123 nanophosphate. At the moment, however, you have to make them yourself. Which might be a good thing.Electro-Fox said:arkmundi
Thank you so much...what a great response.
I have been thinking of getting the Em3ev Triangle pack that they sell. Specifically the INR18650-29E...16.5Ah 825Whrs... This is not Lifepo so is this a safe way to go? What is your opinion of this pack?
Cephalotus said:If you want "the best" battery do not buy any LiFePO4 pack from China... period...
Depending on the maximum current and the maximum recup current(!) from your motor I would go with a pack made of some Panasonic NCR18650 cells, if you have lots of money to burn the BE type, if you want something chap and good the PF. Add an excellent BMS (or use a charger with balancer) and avoid overheating the pack (this includes storage).
If you can avoid heat the pack should survive 15+ years OR 1000+ cycles form 4,1V to 3,0V (incl some low recup cycles).
The best thing vs LiFePO4 blocks is that you can make it custom size to fit your bike nicley, rather than having this huge and heavyweight LiFePO4 block hanging "somehwere" on the bike or between your knees...
If you have a well designed battery pack it doesn't matter where you ride it (except that heat will degrade any Li-ion cell, NCA is less senisble than LiFEPO4/LFP and that less sensible compared to LMN)
Just my opinion.
You'll get hammered with much diverse opinion here on the forum, so need to sort it out. You'll get good results from either:Electro-Fox said:Anyone you could recommend?
