999zip999
100 TW
Give us a link to your motor kit or more info.
http://electricbikereview.com/falco/hx-500/Electro-Fox said:This will be used with a Falco 500 watt hub motor, which uses an internal controller. I can use a 36 or 48 volt but thought that the 48 volt would be the best choice. Isn't LiPo4 the best chemistry?
Electronic Details:
Motor Type / Nominal Output : / Peak Output : Rear-Mounted Gearless Direct Drive Hub (5-Phase) / 500 watt / 750 watt
Motor Brand / Motor Torque : Falco / 40 Newton meters
Battery Voltage / Amp Hours / Watt Hours : 36 volt / 11.6 ah / 417.6 wh
Battery Brand / Chemistry : Panasonic / Lithium-ion
Estimated Charge Time / Estimated Min and Max Range : 6 hrs / 20 to 70 miles (32.19 to 112.65 kilometers)
The battery on this bike presents a few more options including size and configuration. The standard size is 36 volts of power and 11.6 amp hours of capacity which is a touch above average. It uses light weight, long lasting Lithium-ion cells and weighs ~5.5 pounds. You can upgrade this to a 48 volt pack that offers more power and can propel the bike faster if you get the computer console option and an unlocked kit. I’d say, if you do a lot of climbing or weigh over 180 pounds the 48 volt option is worth considering.
teklektik said:EF-
Not to be rude or harsh, but this thread is all over the place - you cannot possibly hope to get meaningful answers...
This is like walking into a bar and shouting - "What's the best pickup to buy?".
- The title itself unequivocally demands LiFe - and yet here you are on page 3 making a buy decision about NMC/NCA cells.
You are going to use a fork bag and won't consider a triangle bag - but now are going to use a triangle bag (goes to cell form factor).
You are concerned about 6% weight difference in NMC/NCA cells but started off with the heaviest/lowest energy density battery (LiFe).
You originally wanted to just jam as much battery as possible into a fixed bag size but now are asking about range.
You haven't given any distance for the commute and say nothing except that it's flat and you pedal a lot (which is easy on power consumption) - don't talk about traffic start/stops (which eat power), and then say you want to pull a trailer (which eats power on starts and hills), and want to ride in the snow (which is incredibly taxing) --- so basically a wide spectrum of use from super light to super heavy with no distance requirements.
And above all else - you didn't want to "go to school in order to buy a battery" and now are asking semi-technical questions, after having discouraged actual technical advice in favor of 'opinions'...
You can be certain that succinct and well-considered answers meeting your exact needs will ensue...
There is nothing wrong with asking noob questions, but you are starting out with critical constraining decisions, then reversing yourself. You may be frustrated by the variety of opinions expressed here - but you pretty much set the stage...
If you really don't want to understand this stuff, then just buy a big-ass battery from Ping or EM3EV (both well respected vendors with completely different offerings) and enjoy whatever it will do for you. Experience will fill in the blanks you don't wish to investigate up front. This generally works okay and frankly is the basis for many of the opinions you solicited - buy and learn.
Otherwise, slow down, read more and ask more fundamental questions to help you balance the tradeoffs - before making decisions that (unknowingly) severely limit your options and results.
That said - here's some technical stuff you didn't want to hear:
A little understanding will help you see the tradeoffs and do a little simple arithmetic to get what is most important to you .
- Your motor has an integrated controller that is rated at 35A @ 36V and can be adjusted up to 50A (about right when hooked to 48V - but you could leave it at 35A with 48V and give up some torque). It's your controller amperage as well as cruising current draw that must shape your battery buy.
You will need to choose a cell type such that the Ah rating times the 'C' rating matches the controller current draw for both Max (getaways, hills, etc) and continuous use (cruising - normal start/top and mean speed and load (snow!)). So a 15Ah pack with a nominal 2C rating will provide about 30A of current whereas the same pack made with 5C cells will provide 75A. If you continuously flog the battery at close to capacity it will have a detrimental effect on cycle life so many folks use a '1/2 C rating' rule of thumb as a tradeoff to minimize flogging and extend cycle life. Here is where that whole business about 'type of use' comes in (that you answered as 'every use from light to super heavy'). Running light loads will let you use a Ping - no problem since they are 2C batteries. But load the crap out of the bike for long periods in the snow and you need a higher 'C' rate (or Ah capacity) battery to carry the load without being damaged (eg one of the EM3EV batteries). So - pick your cell type based on use OR limit your use to match the cell type you can afford to buy or carry...
- Your range (without fudging for lots of start/stops, hills, etc) is:
Range = (Wh capacity of your battery) / (Wh/mi consumption) * (percentage Depth of Discharge)
Your DoD is probably 80% for LiFe and 90% for NMC and NCA (DoD = cycle life vs capacity trade-off - more opinion...)
You are a heavy pedaller so your consumption may be as low as 10-15 Whr/mi on the flat. In the snow it might be way more than 60. For comparison, it takes about 13whr/mi to move a mountain bike at 15mph without pedaling, about 21Whr/mi to do 20mph, and about 40Whr/mi to do 30mph. So what's your range? Well - from your specification (which is: many widely varying uses) - we just can't tell - it will depend...
No one here want to dissuade you from posting, changing your mind, asking questions, or fault you for generally being overwhelmed by all this confusing stuff...Electro-Fox said:... I take no offense whatsoever, and thanks for the info.
I will take it from here and the admin can just close the thread as I will figure things out by just reading things already posted.
teklektik said:EF-
I'd be willing to make AMP20 packs using OSNPower provided cells and their kit and my cut aluminium plate, duct tape approach to construction at cost plus $12/hour labour, 100% cell cost up-front, balance-due on ready to ship. Expect low-interest, which would suit my cottage-industry approach to eBike services. Pack would come with wiring harness and Celllog 8S and/or balance charger leads to each cell. I'd warranty it for 1 year, with the right charger.John in CR said:"The best lifepo4 battery....period." I believe remains one built with A123 A grade cells.
teklektik said:Electro-Fox said:...
- This is like going to a car dealership without really understanding engine choices and proclaiming right off the bat "I want a car with a V8 - Period!". The salesman can only think you understand what you want and go from there. He has limited time and resources and it doesn't look like a case where talking about the advantages of other options is what you want - you have been very specific about your desires.
Now - if you had started by saying "Help me understand my engine choices" or "Is a V8 a good choice for what I want to do?" you can be certain the conversation would go differently.
A little offensive man...I have done my research and as I speak to people things change and that is why tend to bounce around. All over this forum I hear how happy people are with their Pings, so I thought..."must be something to it." Then I see that they are a heavy beast of a battery...so I change my thinking. One person commented how I was going to put the battery on the frame and then I wasn't. Well that is true...I really did not want to use my frame up...until I realized that the Pings were so damn heavy and big, and so I went back to the drawing board. Then someone explains that the 18650's are a much smaller pack...so I go to thinking about that and thought maybe I will have to use the frame after all. Look...just because a person vacillates does not mean that they have no focus. Also...some people fail to read an entire thread, especially when they get really long. I am not the first person to switch gears mid stride.
Now as far as the auto dealer analogy goes, you are using it in a context that makes me the idiot. I have been in sales all my life and many people come in with no idea at all of what they want. What should I do then...tell them to go home and do more research? Hell no...that is my job as a salesman, to listen and help them have some focus. Your way of thinking would get the salesman fired. If you want that analogy to be accurate then it would be like me walking into a car dealership and be greeted by 30 plus salespeople (the forum is the salesman in this analogy) all of them telling me different things. One would hate the Ford...the other would think the import is the way to go. And all of them would sell what they think is best. I would have to sit and listen to each one and of course I would be overwhelmed.
I have talked to many people and let me tell you...most of the bicycle shops that do electric bikes are really rude people...sort of like you. They tell you what they want to say and then berate you if you don't like it. Totally worthless. I spent so may emails with one guy trying to buy a battery only to be brushed off when I called him to make the order.
Falco has become one of them too. I did not buy his battery..the reason for which I will not get into here...so the warranty goes from 5 years to 1 year because of it. The guy has been a real pain to work with. So now what do I do? I spend a boat load of money on a battery and for some reason the motor does not work....well I am screwed. PERIOD. He would do nothing.
Look...I know what you are getting at...being more focused. But try to be a little more understanding, instead of rubbing my nose in it. My frustration has not been helped by your repeated attempts to be right.
Nuff said....
Electro-Fox said:Well I will tell you guys, that I am a mature and smart man, ...
This thread is trending right now and a lot of people read it, and what do they find? Not one, but two posts commenting on how I am asking too much for something I am selling. Anything good about your post went right over my head with that stunt. Shame on you.
gawd almighty...
Electro-Fox said:Another problem is fitting the battery onto the bike. I don't really want to use the triangle as I will just have to move the water bottles, which is inconvenient. I thought about putting the battery in a bag on the front rack but when a battery weighs over 16 pounds, that is a lot of weight to throw on the fork. I have had loaded front panniers and it does affect handling. I want the amp hours as I will be pulling a trailer from time to time.
I notice that Ping (in some cases) gets the capacity by using two batteries...such as this one.
http://www.pingbattery.com/servlet/the-2/lifepo4-lithium-ion-phosphate/Detail
Could I get that and put them in a pair of panniers? One battery on each side? I can get saddlebag panniers or have them made. Then I would need to have the batteries protected in the panniers in case of a crash, but it would eliminate the lack of space problem.
