jhotchkissca said:
[...] I want to be able to ask the bike to help me out and have it respond, like giving me a tailwind. I can ride 60 miles at a 15 mph average with just my legs. I am looking for a boost with the least amount of intrusion on my normal cycling feel (balance, drag, shifting, etc.)
That being said, I am concerned that once I introduce an electric motor into my commute I will use it more and more and eventually lose my hard won legs. But I guess that is between me and me.
I don't need a 60 mile range at the expense of an oversized battery. I need a 30 mile range with the motor mostly assisting my pedaling.
Hi jhotchkissca,
I think it's readily apparent what your best choice is right there from the parts I've excerpted!
I've just gone through something like you are in your decision making process but I'm a bit more informed today than I was when I first posted (just like you, I bet!), and the best thing I read on the subject was right here on this forum, on this page:
https://endless-sphere.com/forums/viewtopic.php?f=28&t=79788&start=375
That link goes to the end, but I started on page one and read all 16 pages and am now quite convinced that the e-bike solution presented there is the best one for you because it discusses the smallest, lightest weight, most efficient solution out there, and, as you importantly point out, you don't want a moped; the TSDZ series (TSDZ2 and TSDZ3) are assist-mode approaches! They only provide assistance as you yourself give power. When you give no power, the system gives no power, when you give more, it gives more, when you give a lot, the system assists you a lot - EXACTLY what you are asking for.
Best of all, no worries about modifying your brakes and such to cut out the motor when you dont' want it, no distractions from having to deal with a throttle, none of that. And the range reported is amazing, in large part because you, the rider, are still contributing a lot!
I'd give a testimonial but I only decided on my own path today and still have yet to receive any pieces. However, LOTS of others have given their testimonials in the thread and on the pages I cited. ... Here's what I'm about to add to my own bike:
Tongsheng TSDZ2 Mid-Drive kit, 48V 500W 42T Chainwheel Electric Bicycle DIY Conversion With Torque Sensor
http://auto-ebike.com/index.php?main_page=product_info&cPath=25_1&products_id=1780
48V 10.4Ah SANYO lithium battery electronic bicycle with Charger and USB output:
http://auto-ebike.com/index.php?main_page=product_info&products_id=1738
Expecting about three weeks in transit and a total cost of about $600 plus my wrenching the parts onto the bike. There are larger batteries, of course, but I don't need the range you do daily, and when I do need long range, my plan is to use an automotive deep-cycle Yellow-Top Optima (I already own) with a DC-DC converter to feed the system, putting the huge (59 pound) battery on the heavy-duty luggage rack I built for the bike. Instead, you might well get away with a 15Ah or 20Ah Lithium Ion battery in a much more conventional packaging.
Lets keep in mind here; this is an assist package. The other suggestions here are basically about turning your bike into a moped and this solution does not do that! SO, you do NOT need the same battery as their solutions would. Also, the system stops when you do, so it's very efficient that way.
The Tongsheng units are NOT the only "torque-sensing" units on the market, just the cheapest. Maybe you're up for another model. I understand Bosch makes one. I'm not sure who else, but I'm sure that now you know what to look for, you can find them.
Best wishes,
RT
