I, with some students, would like to build a stationary bicycle power generation station to be used as part of an energy course in a high school. I have built one of these before using a bike on a trainer that spun a car alternator through a belt drive. The alternator regulated to about 14V which was fed into an inverter (cheap modified sine wave variety) to drive AC loads. This setup was very inefficient in converting human power into AC power. My guess is 50% overall at best considering the alternator by itself is less than 60%.
I thought a more efficient setup would be to use a hub motor e-bike in regen mode. I have no experience using hub motors or regen as all of my ebike builds have been non-hub drive without regen. Has any one done this before? What kind of efficiency could I expect? I would still need to have some amount of battery power to energize the controller and get it to regen. Maybe a low kV wound hub motor with a 3-phase rectifier feeding a DIY step down converter? Ideally the key is to get regulated 10V-15V power to feed the common <1000W inverters, preferable pure sine wave inverter. It would be nice to be able to put as many off-the-shelf components together for a rapid (< 2 weeks) solution. Subsequently I will add an arduino based power monitoring/logging system to allow students to do some experiments. Please share any ideas you may have regarding this project.
Thanks.
Martin
Thanks.
Martin
