Being close to a weight limit of something is certainly something to worry about. Frankly, it might be hard to know if it can really withstand what it claims to be able to.
The idea of reducing leverage by keeping the bike closer to the body of the car seems like a wise suggestion.
I have some other suggestions that might also be of use. I don't know what your trip is like, what sort of excess carrying capacity you have, but I imagine there are a couple of things you can do to reduce the load on this bike carrier of yours. First, I imagine there must be somethings you can take off the bike and put else where, surely anything is better than removing nothing. Whatever you can do to make the bike lighter, it might help. Next, this might require a whole lot of creativity, but I bet you could create a sort of suspension system that involves a series of straps. I don't know what your vehicle is like, but if it's a four door, you could keep the windows cracked on the rear doors, and run a long rope in an X patter from each window, so the left window rope attaches to the right side of the bike, and the right window rope attaches to the left side of the bike. This is probably a bit more involved than you'd like to be, but my next suggestion might be far more involved. You might be able to reinforce your rack, but this might be a tough call to make depending on various conditions within your frame.
If nothing else, this rope system can be used to take up a bunch of excess weight and if the rack should fail, it might prevent things from totally falling apart on the road involving a bike and rack smashing into a vehicle behind you.
Personally, I think the best course of action would be to sell that thing, maybe use it as some sort of template, and get some sort of welder (stick and flux core welders are very affordable) so you can fabricate your own that isn't a light weight, ready to fail under the weight of a single bike piece of over priced junk. I cannot read what this amazon ad says for this bike carrier, but I saw the word aluminum, if it's made out of aluminum, I'd certainly get rid of it of you were considering doing something like getting close to over loading it. Steel will bend, aluminum will crack or shatter. If you want to learn more, look into fatigue limit.
