slayer said:
OK,
The BIONX Lithium battery only have 4 wires:
negative, Positive, and two for the temp sensor.
Doc
I hink you are not correct, you own diagram clearly shows CANBUS going to battery.
strange that nobody still not noticed.
BIONX BMS obiously must communicate with rest of system, how else display can display battery SOC?
Doctor are you there?
I think the way to go is just to replace cells not to mess up system with third-party battery unless you are talking about replacing old BIONX NMH battery with lithium.
BIONX lithium cells are pretty high quality, I am sure, DIY guy cannot get much better cells.
you must maintain CANBUS communication , no way BIONX will work with broken CUNBUS communication.
in this regard it is quite close to EPLUS ebike system which I modyfied from NMH to Lithium.
