Kingfish said:
grindz145: If the voltage is less than the battery pack, could we not employ a buck-booster circuit?
That is what the PWM of the motor in regen mode does, (or more likely: the shorting of the coils momentarily then reopening them so that the resulting voltage spike as current flows again is much higher than the battery pack).
Kingfish said:
Alan B: I’d like to comprehend; are you saying that by virtue of the design to be a motor is not so great a design to be a generator?
No, just that any motor spinning at a particular speed relative to it's windings and magnets has a particular voltage it will generate, whether it is in motor mode or generator mode.
In motor mode that voltage is what limits the current you can force thru it (and thus the acceleration you can get out of it), as you have to have a difference between that voltage and the voltage you are feeding it from the controller to get current to flow. The higher the difference, the greater the motor power output.
In generator mode, that voltage is what can be tapped to feed a battery or a plug brake (resistive element). When feeding a battery, then again the difference in voltage between the battery and the motor output voltage will determine the current flow, and thus the load on the motor/generator, and thus any braking effect. Bigger difference, bigger current, bigger load and bigger braking effect. The speed at which the particular motor/generator is spinning determines how high that raw voltage (BEMF) is, if you do nothing to boost it.
But if you use the controller to boost it (one way is I think called synchronous rectification), then you can increase the effect of the braking, although if I understand correctly you are not boosting the average voltage from the motor, only the peaks (because now it is not producing the voltage all of the time, just in PWMed spikes). I think the average voltage remains the same.
But even though that average voltage might be the same, the peaks are high enough relative to the battery voltage to cause current flow and a load and braking, whereas the constant voltage of just the unmodified motor output might be equal to or less than the battery voltage, causing no current flow and no load and no braking.
When I use regen braking with my Lyen 6FET and a 9C, for instance, then it feels pretty constant using a 36V NiMH pack braking from about 15-18MPH. But using a 48V pack, all other conditions being equal, it feels weak and "pulsey", like it's vibrating, because only the peaks of the voltage during motor rotation are causing current flow and braking, rather than most of the percentage of the motor rotation time.
I may be misunderstanding or misinterpreting what is happening, or misexplaining it, so if I am, please correct me.
(edited to fix my quotes)
