Antonio Zanardo
Jozzer said:Why do you want to run such high voltage though? How about dropping your voltage to match your desired top speed, and upping the amps to match your desired power usage/output?
My answer:
I have 4 lithium batteries, each one rated 28.75V 10Ah at full charge.
I can match them as follows:
1) Two sets of 2*28.75=57.5V 10Ah connected in parallel to get 57.5V 20Ah (which is the present setup I am running with the recently repaired 20A controller)
2) Or a series of 3*28.75=86.25V 10Ah (but this way I have one battery left unused)
3) Or finally a series of 4*28.75=115V 10Ah.
Case 1) the full load top speed is 40 kmh (not mph!)
Case 2) the full load top speed is about 50 kmh (but battery Watts /hour available is less than case 1 and 3)
Case 3) the full load top speed is about 60 kmh
I cannot increase amps as I was told it won't be advisable to draw much of amps from lithiums, anyway the current is limited to 20 amps by the controller.
Of course 60 kmh is the top speed I prefer to count on, just in case...
However my usual cruising speed is a modest 30-35 kph.
Antonio Zanardo
P.S. Is there a way to know if my lithiuns are cobalt or polymer type?
The Amperex factory says they are polymer while Brett who sold them to me says they are cobalt. Who is right?
