How do I convert a 48v 30amp 9 fet 3977 controller to 72v 40 amps
ScooterMan101
Power poster
SF Bay Area California
I have a Lyen Controller 9 fet 3077 mosfets , from what I can see on the outside it is exactly like the controllers vendors like eM3ev.com and others , sell that list them at 48 volt 30 amp controllers.
How do / Can I exchange a couple of parts inside to make it work on 36-72 volt and 40 amps ?
Higher Voltage is more important to me than higher amps for the motor I will be matching this controller up with.
so up to 40 amps would be good enough .
In other words If I would have to change the fets for higher amperage I would just keep the amps the same, and just change out the parts for higher voltage.
Also
There is a electronics supply warehouse that sells many parts at good prices just around 30 miles from me so getting higher voltage capacitors is easy and last time I was there I thought I saw some for under $8 each.
I have opened up a couple controllers now and have no idea which of the round cylinders are for voltage or amperage or just capacitors, and what a shunt looks like , and what exactly to change out .
A video on how to change out parts in a controller is very much needed for the DIY Community .
If you live in the SF bay area I will donate/ give a controller to you that you can keep, in exchange for converting two controllers for me and making a video so other people around the world can learn how as well.
My soldering skills are not there for small close , together parts that are on boards.
( Amberwolf I read a post by you where you said one still works on your SB and a controller from someone else blew the first time you tested it,
So
Keep in mind anyone reading this that the Controllers that I have that I want to mod have the plug for a Cycle Analyst, and I have the Cycle Analyst that I will be using with the Controller that will be modded , and I know how to set the amp limit in the settings on the Cycle Analyst .
Therefore I am willing to do a shunt mod as well as higher voltage If the 9 , 3077 fets can handle it .
What can 9 , 3077 fets handle ?
They all look the same on the outside, regardless of what they are on the inside. ;)
More voltage requires changing any capacitors and MOSFETs that aren't up to the max voltage it'll see. I recommend a margin over what you need, at least 20-30% (to account for voltage spikes and component aging over time), but some people ahve run stuff on teh ragged edge successfully. Probably 100v FETs and caps will work. Use caps that can take at least 103C; they'll last longer in the heat inside the controller than the lower-temperature-rated units. I personally prefer Panasonic or Rubycon; have not had problems with those brands, when ordered from known-good sellers like Mouser, Digikey, etc. FETs there's a lot of choices nowadays; dunno what's popular (IRF4110s probably fine, but they're also widely counterfeited, so have to be careful where you buy from).
It also probably requires you change the fat resistors in the low voltage power supply section (where the "keyswitch / ignition" wire to a higher resistance, proportional to the change in voltage. Otherwise, the current flow thru them will be higher, and they'll heat up more, and possibly burn out (some poeple have had them burn the PCB itself, and come unsoldered, floating around inside the controller shorting things, while keeping the controller from operating becuase the MCU can't get power).
HIgher amps is often easier to get than higher voltage, becuase it seems quite a few controllers will handle 10-20% higher currents (or evne more for really short periods), and some can simply have their shunts modified, replaced, or added to, to get higher currents. Some are even just programmable to higher current limits.
Shunt mods can be very unpredictable in their results, though, becuase you can't really know exactly how you are changing the shunt resistance. WHne you do this, you make the controller unable to "know" what the current really is, so it can't protect itself from overcurrent anymore.
If you have extra shunts out of an identical controller then you could parallel them for more current. If the original had four, and you added a fifth, you'd increase current by 25%. If it had two and you added one, it'd go up by 50%. If it had one, and you added one, it'd double the current. Theoretically, anyway--actual results do vary, sometimes from controller programming, sometimes from controller powerstage design, or even the motor attached, the load, etc.
I added a third shunt to a generic 15FET, and went from about 33A max, to 80A max--way way way more than predicted! Something else is probably also affecting it, most likley the shunt I added is much lower resistance than the existing ones (but I have no idea what resistance it or they are). I haven't blown it up yet, because it sees taht peak only for a second or two as I startup from a stop, and it's also spreading the load of the trike with a second motor and controller (albeit an unmodified generic 12fet of similar rating as the other started out as).
The main thing about higher current is that it makes more heat, so making sure that heat quickly gets out of the FETs and the controller is very important. The more you "overclock" a controlelr for more current, the more important it is to ensure the FET heatsink bar that they're all bolted to is fully and flatly contacting the case, and that both are very smooth and flat so there are no gaps between them when bolted together, and that whatever heatsink paste you use between them is applied very very thinly to only fill any scratches/etc to remove airgaps.
The caps should only cost a couple bucks each, to maybe four. Noname / "generic" brand caps would be like a buck each for 100v 1000uF.
All of the round cans are capacitors, and only affect voltage.
The shunts look like fat wires about half an inch to an inch long, that just "jumper" across a gap over by where the big fat main battery power wires come into the controller board.
FETs are for both current and voltage.
Yes, there have been a few blown ones. One was blown when I got it because the original owner had accidentally reversed power to it; it was fixable with a new shunt and caps, and it still works even now. One that blew when I tried it out was a modded 18FET; I forget who by, maybe Methods? was a long time ago--but it fried trying to get CrazyBike2 going; I think I was trying to get it to wheelie. :oops: It just couldn't handle the overcurrent from whatever mods had been done to it; it had no way to control the current becuase it couldn't know how much current there really was, so POOF.
The one I added the shunt to still works...so far. ;) But it (and the other generic) are getting replaced by a pair of Grinfineons as soon as I cna build the new wiring harness for them (and depending on results I may mod *those* for more current, too, but only if they won't let me haul the loads I need to with quick enough acceleration--I'm much more interested in perfect reliability on the trike than performance).
The CA will no longer read current correctly either, so its amp limiting will be wrong too, just like the controller's. The only way the CA could properly read the current (and thus do any limiting correctly) is if you knew exactly what the new shunt value was, and programmed that into the CA, *or* if you buy the external (SA) shunt from Grin and used that instead, just for the CA to know exactly what the current really is.
FWIW, it is probably cheaper to buy new controllers that handle the voltage and current you want, than to mod the ones you have--generic controllers are pretty cheap these days, and all the FETs and caps can cost up to twice as much as the controller, depending on what you need it to do vs what it did before, and what features you need. Especially if the higher current/voltage turns out to be more than what something else in the controller can handle and it takes out other parts than those you modded or replaced already, and you have to repair those too. (and if you use new ones you still have the old ones as working spares....)
A quick google finds a number of 72v 40A controllers for as cheap as $40 with free shipping (DOMINTY on Amazon), but I have no idea of the quality. The generic I shuntmodded that still works was about that price, I think.
At a guess, genuine IRFB4110s will probably cost around $5 each for 10 or less of them, possibly including shipping. So there's $50 already. There's probably 2 to 4 caps that will need replacing, if they're $2 each, there's another $4 to $8, higher if they cost more ($20 to $40 at the prices your local place charges). The resistors in the LVPS are probably a dollar or two.
So guesstimate $60-$100 for parts to upgrade each of your controllers, not including oopses in assembly or testing.
I will have to check to see if those cheep $ 40 controllers have the C.A. plug.
I had a chance to buy one but it did not have the C.A. plug so did not buy it,
I have no idea at this time how to make a C.A. work with a controller that does not have a CA plug.
Shipping from Grin to me is at least $ 12, so if there is an external shunt that would work from grin there would be that cost and shipping added to a $ 40-$ 60 cheep controller.
But the main Reason to mod the controllers I have is the fact that I have them and would rather use what I have than to buy something else . Last time I bought something From BMS I also bought two 6 fet 36/48 volt 22 amp controllers , and I have a couple of generic small controllers , lying around so you see I have enough stuff. Along with a few more hubs that are not built up yet . ( two not laced / built up and one is a front in a 24 inch wheel.
So I am
Trying to use what I have before buying anything else . ( besides the mid-drive that I bought a couple of days ago that should be on its way to me right now, which is what the controller is going to be for )
They won't, but you can add one easy enough--much easier and cheaper than modding a controller for higher current and voltage. ;)
Depending on what you're doing with the CA.
If just monitoring, the easiest way is just to use the SA shunt unit from Grin Tech, which goes in series with your battery wires to the controller, and then the CA plugs into that. This lets you monitor the battery current, voltage, watts, etc.
It doesn't let you pass throttle into the controller if you're using the CA for limiting/etc; but you could use the external throttle wires for that.
Monitoring speed would be done with the external wheel sensor. (which you would need anyway with a middrive, as hte middrive motor isn't running at wheel speed, so the CA plug won't give the bike speed, only the motor speed).
Fair enough--I like to use what I have, too, but as my eyes and hands (and brain) have become a lot less able to work on small stuff, I've gotten more likely to save up the money I'd've spent on the modification bits and spend them on better replacement items instead (which is why I got the two sinewave Grinfineons, along with some other bits and bobs that *are* for modifications to stuff I already have ;) ).
I did enough of the controller modding and hotrodding and fixing that I am not really all that up for doing it anymore unless I have to. I actually have a pair of brain and power boards to build a couple of lebowski controllers, which would, once tuned, really likely do exactly what I want, and the main thing holding me back is the about $500+ for all the parts needed to do it right (I started collecting the parts out of stuff I had laying around, but turns out that most of the pieces I'd still have to buy; just don't happen to have them).
Anyway, if you still really do want to mod the existing controllers, you'd need to change, at minimum, the stuff I listed before.
