Spacey
Can someone help me with the positioning of the sensor wires?
In the diagram below it looks like the sensor wires go on the negative terminals on the cells with the last sensor going on the positive on the last cell....... But the headway pack with this bms arrived with the first sensor wire going to the negative terminal on the first cell and the all the positives in the pack. This seems out of odds with the wiring diagram or am I reading the diagram wrong?
Don't want to break yet another bms.
Spacey said:Starting to think that maybe ... just maybe I am at fault and wiring up my BMS's wrong.
Here is one of my BMS wiring diagrams sent by Michael at Evassemble:
This is how I have been wiring it up (probably wrong):
Step 1: Hook up the B- on BMS to the Negative on main Headway pack (Negative first cell)
Step 2: BMS Sensor wire "0" also goes to the same cell as Step 1 i.e first Negative on pack
Step 3: The rest of the sensor wires go to the Positive on each cell until all done
Step 4: P- is the charging Negative terminal
Step 5: Out- is for the main discharge negative out
This was how my Headway pack arrived wired up but I get confused as some of the light come up red as the pack nears the end of charge.... the charger then stops until the red lights go out (slowly discharging the high cells I guess).... then the charger springs into life again until the cell lights come on again then.....it stops never to restart. Seems it only ever restarts once.
I thought that it would do this constantly until the pack was balanced.
