OCD Garage
Yes the section in the arrows is 1/4" plate, drilled at one end, angle grinder to cut the slot up to the hole, then welded into the 1/8" rectangular tube which already had the side slot cut into it. There is also a 1/4" plate torque arm/caliper mount that slides back and forth with the axle. I don't anticipate it coming apart any time soon, I'm more likely to snap the bottom bracket mount off. Chalo may disagree however.
