docw009 said:Well, if you can see the 7805, why not check the output. Left side is Vin. Ctr is Gnd. Right side is %V.
How do I go about this? Simply connect the multimeter set at 20V DC to the two sides?
e-beach said:On the controller side of the motor cable check your connectors with the ohm meter. When you test Blue to Green, Blue to Yellow, Yellow to Green (or what ever colors you have) you should get an open reading --- No connection between any of them.
Check the phase wires against the axle. Connect one probe to the axle, make sure you have a really good connection, and probe one of your phase wires to see if you have continuity. If you do, you have a phase grounded internally. If no continuity, that is good. Test the other phase wires in this way.
e-beach said:Checking the Hall Sensors with a power source:
Do you have a 5v power source? Connect the 5v supply to your Hall sensor positive and negative. Make sure you do not short anything!!! Then go through the process from the pdf I linked on testing Hall sensors. (this one: https://www.ebikes.ca/documents/HallSensorTestingFinal.pdf)
The motor wires should not show connectivity. If you disconnected the motor wires from the controller completely, and they showed connectivity with each other then they are shorted together. (an example is if you completly disconnect the motor wires and probed the blue and the green connectors of the motor wires and have connectivity, then you have shorted phase wires.) What that also means you may have blown one or more fets in the controller.marc123 said:All three running out of the motor however do show connectivity, which I guess is normal?
I suspect the edges of the opening in the axle (where the motor cable enter the hub) cut through the insolation when the wheel spun out of the droupouts, and this shorted the controller. I wrapped electrical tape around the cables so that they can't touch the axle, and I'm thinking this should avoid any further problems.
Yes, the black and red wires of the hall bundle is where you hook the 5v source to. 1.5 amp is probably too much as the data sheet for the Honeywell SS41's call for 10 to 11 mA. It also states that it can take a 24v maximum meaning a 9v battery should be ok. Although you are working with unknown Chinese electronics.Two questions here..
1) When you say connect the power source to the hall sensor, you mean the black and red wired of the hall bundle running into the motor? I have a 5V 1.5A phone charger...should that be alright, or too many amps? After this, what I'm looking for is the oscillation between 0 and 5V when I turn the wheel, correct?
2) Could I possible just supply power to the throttle with this same 5V phone charger to see if, when it receives its needed 5V, it actually causes the wheel to spin?
e-beach said:The motor wires should not show connectivity. If you disconnected the motor wires from the controller completely, and they showed connectivity with each other then they are shorted together. (an example is if you completly disconnect the motor wires and probed the blue and the green connectors of the motor wires and have connectivity, then you have shorted phase wires.) What that also means you may have blown one or more fets in the controller.
marc123 said:All three phase wire run together into a tangled braid of copper wires inside the hub..how could there not be connectivity? Are all these wires coated? How can I find the short in this tangled mess..
e-beach said:Sorry that was my mistake. You should get an connectivity when testing the motor wire bullet plugs. What you should not get is cogging when spinning the wheel. (before posting, I tested a known good motor I have to verify my statement on the phase wire testing, as it turns out the meter I used has a bad ground probe..... Anyway I retested with a better DMM and you are correct.)
So how did the throttle and Hall sensor tests turn out?
marc123 said:docw009 said:Well, if you can see the 7805, why not check the output. Left side is Vin. Ctr is Gnd. Right side is %V.
5v to the throttle is good. What is the return voltage from the throttle?marc123 said:*update*
The new controller arrived today, and the bike works, although only via the PAS. The throttle is getting its standard 5V, but won't cause the motor to accelerate as it should. Any ideas?
e-beach said:5v to the throttle is good. What is the return voltage from the throttle?
e-beach said:Try a new throttle.
