SkywalkerLuke
- Joined
- Apr 28, 2016
- Messages
- 3
Hello guys,
so I am trying to build an electric bike using MY1016 24V brushed dc motor and I encountered a problem that I hope you can help me with, since I didn't manage to find solution by myself. For the setup I used following: motor is MY1016 24V 250w that I mentioned above, controller is Yiyun 24V 250W (LB27) that I ordered from ebay, battery is custom built 6S1P 24V li-ion (just for testing in this phase, it works well) and finally thumb throttle also ordered form ebay.
Problem I get is this: when I connect all components together, on full throttle I get only 5V on motor output. What is strange to me is that when motor is not connected I measure a little bit less than 24V on motor output with full throttle. Voltage measured between black and red throttle wires on full throttle is 5V, between red and green is 3.2 V and between black and green 1.8 V. When I connect motor directly to battery it spins nice and fast like it should. So I am wandering what could be the reason of voltage drop from 24V to 5V when motor is connected ?
I have two same Yiyun controllers and on both I have same problem. Outputs on controller: motor, throttle, power locks, charging port, indicator, brake light and brake.
Please excuse me if there is simple obvious solution for this,because I'm still a little bit newbie , and thank you very much for any help and suggestions.
