Yes, with room to spare.
The big triangle and cylindrical tubes are major benefits, and the compromises should not be an issue in your application.
The bottom bracket area’s only really stressed by out of the saddle riding in big gears.
Skinny stays I’m not sure about. I’ve had bikes that suffered tire frame and fork rub leaning hard into corners, but they were boutique road bikes with tight clearances and super skinny stays/blades … and it was likely just the wheels flexing.
Skinny top tube I would expect to only be an issue with a loaded rear rack. Even five or six kilos on the rear and you’ll feel the tail wag with any sudden direction change. And a bike that does that is almost guaranteed to develop shimmy at some speed. IME around 30mph, but could be any speed.
I’ve no idea how the central battery affects things, whether it counteracts or contributes to shimmy. So, again, I’d want to test it with a dummy load rolling down a steep winding hill to see.
It is worth doing. Other than step through frames, the only bikes I’ve had that shimmied had long skinny top tubes.
