ponch37300
100 µW
- Joined
- Mar 17, 2010
- Messages
- 9
Thanks for the help Jeremy.
I think I can find an SCR on ebay for a reasonable price.
As for the electrods, after reading I saw that some copper chromium were a good choice. I found some on mcmaster-carr for a good price so I ordered some to try. If they don't work I can always run to the local hardware store and buy some solid copper ground wire to use.
I am looking at power supplies right now. Is there a minimum amp rating that I need? There are some cheap ones that are up to 10 amps, then there are some more expensive ones that are 25-30 amps and up. I would like to get a medium range one to keep the costs down. So what is the minimum amp rating that I need to weld battery tabs. Not looking to weld anything more than battery tabs for now.
I am going to look for a 5 fared or so capacitor for now. Maybe build up a bank of capacitors down the road.
So besides the power supply the only question I have is about the relay. You say that a normal car relay will work so I should be good because I have a bunch of them laying around. Can you provide the details about how to hook the relay up? And also what size wire should I use for the connections between the power supply to caps, relay, etc?
Thanks again for your help and hopefully will be able to post some pics of my battery tab welder soon! And once I get the basics down I want to design a setup that will use a foot pedal to lower the electrods to the batteries and thinking a limit switch to trigger the relay. To make it "hands free" so I can hold the battery and use my foot to lower and trigger the welder. This will be down the road, just focusing on a basic welder for now.
Scott
Scott
