Catatopatch
New here
Hey guys! This is for me and my group members Bachelors Project for EE, we are all pretty new to the field of Ebikes, but our project is just to showcase it working/record some values/possibly make some components like the controller cheaper etc
Basically my group decided to go with these as our motor/controller/battery & adapter based on what our professors recommended, as well as input from multiple people on our last forum post
Motor: 24V/36V 200W 5 Inch Electric Scooter Motor Wheel with Solid Tire 5" Electric Brushless DC Gearless Hub Motor with Hall Sensor, Replacement Wheels - Amazon Canada
Controller: https://www.digikey.ca/en/products/...670?s=N4IgTCBcDaIEIFoDiAWAzARkQUQMoGEMQBdAXyA
Battery & Adapter: https://www.digikey.ca/en/products/detail/mean-well-usa-inc/GST60A12-P1J/7703712
https://www.digikey.ca/en/products/detail/mean-well-usa-inc/YP12-YC12/7707223
And our goals are to
a) Showcase regen braking and get some energy back which we can store in a supercapacitor and measure
b) Design our own controller based on the B-G431B-ESC --> requirement from prof
c) Design a buck/boost converter to step up/step down the req voltage/current
I just want to ask, how would we design our own controller/is it possible to based on the ESC that we have already? So like I saw online that ppl have built their designs using this esc by connecting the 5 hall effect sensor wires from motor to the esc, the single phase (positive/negative) battery wires to one end of the ESC, and the 3 phase wires from the motor to the other end of the esc like the diagram below
So Im wondering if its possible to just copy the components used from the schematics for only those things (like the resistors/mosfets etc), and we should be good? Im also not really sure on how we could add the code that we have to create on SimpleFOC to the controller in this case to handle speed and such, as im assuming on the actual controller we upload the SimpleFOC code through this port here. We do have potentiometers and stuff to change it, but yeah Im not sure how to first upload the code into the controller
Im assuming the schematic for the connections and components between the DC (battery) to AC (3phase motor) on the controller is the image below from STMicroelectronics on this specific controller: https://www.st.com/en/evaluation-tools/b-g431b-esc1.html#cad-resources
So if our group builds that the dc to ac wiring should work fine? Or is there anything else that is necessary that we need to include as well? Im also going to try to find the specific schematic for the 5 hall effect sensor connections as well later, but the image below should be for the input DC to output AC?
Thanks a lot
Thanks a lot
