Gee lfp, didn't mean to get you upset. KF mentioned the possibility of making the pc board accept to220s, and I said I didn't think it would be much problem.
You are one of the smartest and most knowledgeable people on ES in my opinion. If your price for participating is that we never mention to220 again I'm all for it. I've known for decades that they were shit. Why we used to use TO3 if we needed to dissipate heat. Only only reason the to3 went obsolete was they were large expensive and hard to use. (And no, I'm not suggesting trying to find to3 mosfets
If someone wants to use those little transistors, they can bend the leads, (and not tell you about it).
That 75A lead limit does sound bogus. And I noticed that they allow themselves a HUGE variation in lead cross section. Might make transistor purchase interesting. Even the smallest should be good for 100A you would think though.
I suspect that you're going to want to use it with external buss bars mostly anyway. Can't you take the drives from a board designed for on board FETs, and use them for bus bar mounted fets. Could it be modified to drive the big, block FETs? Are you using them yet? How are you driving them?
I'm all for lower voltage and higher current. I don't think we SHOULD be using 150V on an ebike. It's partly because of a dearth of high current controllers that the commercial motors use relatively high voltage and low current, (and the cost of copper). But, THIS controller should ALSO be backward compatible with the commercial motors that most of us will want to use it with, if it's going to attract enough contributors to make this project succeed.
KF
I'm fine with 6 FETs, but would vote for keeping it at 12 if it didn't cost much, esp in terms of drive complexity, efficiency or speed.
I'm for anything that will make the design more versatile without adding much to the cost or limiting it's functionality.
It seems to me that the more versatile it is, the more contributors you will attract, and the more likely the whole project is to grow and prosper.
The modular design pretty much does that, if we can get past V1. After we have a working controller, boards can be designed specifically to drive external fets, or someone can even design a board using to92s (if they think of a reason), or whatever.
If we keep it at 12 FETs, 150V @ 150A+, or 100/200 should be no problem should it. I wouldn't mind building up traces for a maxed out build.
Bob
