CA 3.15 - continually shows 2 Watts when powered on, is this a problem?
ampflp
I have two eBike setups that are similar, one I've been running for a year, it shows 0W when powered up, that's what I'd expect.
New system - shows 2W when powered up (on the basement, on a work stand. This is constant and repeatable. I'm concerned whether there's power leakage somewhere, as my other system shows 0W as I'd expect.
Differences between the two systems - the new one has a slightly smaller motor. the new one has the baserunner controller inside the battery, where the old one has the baserunner externally attached to the battery.
Appreciate any advice!
It’s not a big concern. You have to zero the amps. I usually show about 4-5 watts when my bike is first powered on. The lights draw about that much current. Check out section
“6.13.1 Zero Amps”, in the Cycle Analyst manual.
Thank you so much! That resolved the issue completely.
