Can anyone read Chinese?
ebike11
far away
Got this metal spec tag that was on one of the APT controllers.
Im assuming its
350A continuous
650A max current
900A phase current
I tried google translate but I thought someone could translate it better.
Thanks in advance!
Did you try taking a picture and searching that way for the language? I recently did this on a hub motor as it had some Chinese writing on the inside side plate.
You could try to take a picture of each individual line with covering the other sections maybe it will translate that way
I can't read it, but was curious how well a translator would do. Actually, not too bad:
https://translate.yandex.com/ocr
Thinking the "Made of S9" may actually refer to an S9 duty cycle rating. Possibly "Made for S9" (duty)
https://electrical-engineering-portal.com/10-duty-types-three-phase-asynchronous-motors
Thanks
Do you think 350A is continuous and 650 is max battery current?
Thanks
What kind of controller is it? Impressive numbers. Is it water cooled or anything? Controllers are rarely ever rate for continuous power, motors are. I think it will happily peak at 350a for a few mins, but not continuously before thermal roll back/ cutout kicks in. The 650a could be the boost current for maybe a few secs. If you wanted to pull 350 continuously you would a controller that was rated for like 700a and/or has some kind of cooling.
Thanks
Yes it is water cooled but i wont be using that function
