I have ann interest in electric vehicles, and browse here often. But my main hobby is radio control aircraft. And reading this, I coudlnt take it. Someones about to killm themsleves here.
the answer is NO NO NO NO NO NO you absolutely cna not charge lipos froma cosntnat current pwoer supply. If not immediately, they will eventually puff up and explode. They are being irreversibly damaged. Let me explain.
Yes a constant current powersupply is a great asset for charging batteries, and thats a lovely one. But not directly. Even if you where charging nicad batteries, id say, go get a propper charger, the batteries will live longer. But for lipos, its absotleuyl neccesary, all the time, every time. Lipos are charged in 2 stages, constant current (CC) and cosntant voltage (CV). For the first 80 % of the charge, the lipo is charged at cosntnat current (here your power supply would do great) but after that, to avoid damage to the battery, it needs to be charged at a constant voltage. which requires a micro controller to carefully monitor the voltage and current going to the battery and slowly taper it down to 0 amps when the cells reach 4.2 V each. PLEASE for the love of god, buy a propper charger.
This brings me on to my next complaint about your suicidal attitude to charging batteries.
C ratings. Yes sure, those cheap batteries from hobby king say 5C on them, but its common practice on rc plane application to never ever push 2C. I only ever do 1C unless im in a hurry, and even then i charge them in an emtpy metal biscuit box. Just becasue the sticker says 5C, does not mean it can safely take 5C, and 10C is just ridiculous.
The high C-rate Zippy can be charged 5C without any damage, and probably could take 10C before starting to heat
I understand that your only charging them part way. But even charging them to 4 volts is too much like this. And as high quality as it may be, a pwoer supply designed to run server equipment just dosent have the tolerances or failsafes that are accpetable to charge potnetial;ly explosive batteries in your home.
Please, have some common sense. Id consider this bad practice for a tiny battery, but for a huge pack as you see on e bikes, its just plain idiotic. Those batteries easily have the potential to burn down your house. And once youve spent 600 on an ebike, its not worth teh extra 100 for a decent charger.
There should probbaly be a sticky on safe lipo charging, as a lot fo people here seem to be very misinformed. Im not trying to pick holes, but its just plain dangerous.
edit:
Another thing i forgot to mention is that only charging the cells partially makes them more suseptible to going out fo balance, not less. The packs you have quoted are all fairly cheap low quality packs. And at least for the zippy packs, I know for a fact the cells arent resistance matched. This means, sooner or later, its very likely the weaker cells will go out of balance. Normally thats ok, a balancing charger will fix that no problem. But when a pack has likely arrived unbalanced, and is then only charged partially with a power supply, and never balanced. Its the perfect recipe for a dangerously unbalanced battery. Think about it, the weaker cells will keep disharging first, so lets sya in ideal conditiions you start with a 10 cell pack all at 4 volts exactly out of the factory. After a discharge they could all be at 3.5 apart from one cell thats at 3.3 (a very plausible scenario. If you charge it using the mthod you mention it only takes a few charges before the other cells in the pack start getting higher and higher in voltage, before long your overall apck voltage averages out at a nice 4 volts per cell. But one cell could be gettign charged to 4.3 volts (bad enough on tis own), having being charged at constnat current all the way (
:x
). Please buy a charger, pretty please.
nother edit:
One maybe 2 of these would charge your packs in an acceptable amount of time.
http://www.hobbyking.com/hobbyking/store/__6609__iCharger_1010B_300W_10s_Balance_Charger.html
