gogo said:You left out the more pertinent information from Justin's post:justin_le said:So there you have it folks! One thing that became clear to me in these tests though, was that even if there wasn't any saturation/demagnetization effects going on, just the I^2R consequence of pushing the motors this far means we are in a domain that is totally outside of any useful operating zone. The windings get hot, FAST, and that has huge effect on the motor performance. I had the current going through for just 10-15 seconds in order to get a peak torque reading, then would have to put the motor outside in the subZero weather and wait a good amount of time for it to cool off.
it is about when the IRON CORE starts to saturate and not when the windings start to melt.
edit: just because this 9C did overheat quick at that point, it doesn't obligatory mean every other motor will overheat also that quick when the core is saturated. the heat in the windings depends on the phase to phase resistance. a motor with only 28mm wide stator like that 9C also has quite high end turn losses compared to the losses of the copper inside the teeth. a motor with wider stator is better regarding total copper losses.
i would like to know if a high pole count stator can produce more torque as one with a lower pole count at same size.
copper fill should be better with a lower pole stator design as we see on the QS V3 or the Hubmonster..
