As stated above, I'm running multistar li-po in 20s1p.....these are rated apiece at 14.8 and 10ah )10,000mah, the way I will be running them will be 20s1p so the voltage will be 74v at 20ah
Question , I have two ways of charging these ...I can charge them in series with a 72-84volt charger going through a separate balancing board. Or would it be better to charge them with my rc charger in parallel, the charger has a balance built in and I will be using a parallel board in order to charge all the batteries at the same time. Cost is of some concern but it figures out to be about the same, so the main thing I'm looking for is safety and correct balancing of a full charge ....I would very much appreciate any help, comments or better ideals..thanks in advance.
Sorry my original posting was a total mess up I had just got off a double shift at work and obviously was not with the program
