Samd
Interesting thread. Subd.
shaman said:While we're waiting for me to make progress, I have a question. Does anyone have any success stories of fan cooling motor controllers while still keeping the enclosure decently water resistant? A quick search on the internet turns up weird or impractical things for venting an enclosure and maintaining water resistance.
Addy said:qwerkus said:How many? You need to stamp the 2mm cap to create a tiny channel for the o ring, about 0.6-1mm deep. For 2pc, you can use a dremel. Than its just a matter of finding he right sized nitrile o ring.
Thanks for the suggestion. I have 20 of these cases, so I won't be able to dremel them all. I'm thinking the silicone sheets will probably work best for me.
shaman said:PROJECT UPDATE!
Grantmac said:I'd be interested in trying this with my Cyclone. Can anyone compare the assembly difficulty with a megasquirt EFI? I built one of those pretty easily in the past.
liveforphysics said:Love it. Any shot at a 12f layout or a 6f TO247 package version? I would chip in a few hundred bucks to cover some board spins.
nieles said:is your plan to open-source the hardware design?
shaman said:@amberwolf
Thank you very much for the information. It seems like external cooling will be the most practical as pointed out by qwerkus.
@qwerkus
Good eye. I'm hoping that the FETs (and therefore aluminum bar) are stood off from the PCB enough so that a mounting screw can still exist there. It's not ideal, but I don't see another place on that part of the board for a mounting hole. The primary means of mounting the board to the enclosure will be the aluminum bar itself, so one wouldn't even need the mounting holes in the PCB. I can probably have better mounting hole placement on the 12 FET version where I have a bigger board to play with.
qwerkus said:shaman said:@amberwolf
@qwerkus
Ok, sounds fiddly. On the other hand, if you use alu boxes with rails that slot the PCB in (bmsbattery-style) 4 screws in the FET Bar will indeed be strong enough.
Any chance to get a partially populated board ? I don't have a reflow device, and soldering tiny pieces is just a pain.
"Beefing up" the main power line traces is no poblem though. I guess most of us DIY battery builder have some 0.1/0.2mm copper sheet laying around...
wil said:Nice design, keen to see a high voltage VESC design, happy with cheap too![]()
Subscribing
Aside from that one IC(fet driver?) with a central ground the whole thing could actually be hand soldered. Don't suppose there are any other packages for it are there? I'm guessing not since it will be using the ground as a heat sink.
