LI-ghtcycle
Ok, so maybe they aren't really secrets, but I never knew this before!
First off, I want to say that the folks at Clever Cycles in Portland Oregon have been very helpful in my quest in making my own version of their idea, and I am happy to say that I received great info from the builder of the stoke monkey today!
First off, the stoke monkey was designed to work as a bolt-on addition to the Xtracycle cargo system, and therefore after much R & D (even starting out with a RH drive similar to mine using a Nuvinci) they came to use a CLyte 407 as the DD hub motor for their kit because it fit very nicely inside the rear of a bicycle frame with Xtracycle attachment.
The motor that they would have used, if they could have fit it as comfortably as the 407, is the Amped Bikes DD, the same motor we know more commonly as the 9C!!
I didn't get the details of what winding of 9C that they used, however I am sure it would be one of the more common like the 9 X 7 (2807) or 6 X 10 (2806) and Ebikes.ca is the supplier of their motors if I am not mistaken (or at least a resource they used in sourcing their kit).
I just thought I would pass on this information for those considering a hub motor powered "Mid Drive".
I used to think the Stoke Monkey was kind of crazy since it doesn't freewheel if you're on the throttle, but it's just an adjustment to get used to the idea of only using the throttle while pedaling, and it truly is IMHO what the cyclone system would be if it was a little better thought out. Their system using the bicycle's gearing through a LH drive is slow and low powered by most of our standards, but that is the very definition of a cargo bike, slow, heavy and I would say normally cumbersome.
I have been around town seeing Xtracycle equipped bikes and even with my motor, struggling to keep up! (this was an un-loaded bike of course!)
It's pretty amazing that even though it took a lot of pedaling, that he went up a 30% grade in San Fran with his cargo bike loaded to the max, total bike, rider and cargo weight of 480lbs, and most surprising of all, this is with nothing more than 36V and a 20A controller!
Just goes to show, it doesn't take a whole lot of power with the proper gearing!
One other point that the guy at Clever Cycles made ( I'm terrible at remembering names!
) is that on a coast to coast trip like I am planning, there is almost zero chance I will encounter roads as steep as the infamous 30% grades in San Fransisco unless I seek them out on side trips, and anything this steep would just about require me to be riding a bike with a longer wheelbase to be really comfortable.
