Bafang used to have a pattern you could print out to see what the chainline would look like. I didn't see anything like that for the TSDZ8, so you get to be surprised. Hold off until you do the test fit before planning around it."It's down to frame design"
Indeed. I will only know when I install everything.
The stock 44t has about 16mm of offset and the 38t from ebikestuff.eu has 11mm
I need to correct for 5mm. Not sure how thick is the BB spacer they provide, but
I hope I will not have to use it.
