Marc S.
Nice!
PhaseWarmUp.app seems to work fine on my 13" MacBookPro from mid 2009 and OS-X 10.8.5 (Mountain Lion)!
Now it seems, I have to order a Phaserunner... Dude, you cost me money!
Since currently a cheap 15FET/"45A" Sunwin controller is hooked-up to the Bafang BPM (apparently the same BPM version you tested for the Hub Motor Simulator), I've no idea how many phase amps the BPM sees. The CA3 showed 54A battery amps at around 60 volts (15s Konion V3) when I hooked-up the throttle directly to the controller... Interestingly the blue planetary gears held up fine.
Well, since a coloured Phaserunner option isn't on the table, it can be tucked under the seat (where it will still see some air flow), mounted to a sheet of 200mmx80mmx5mm aluminium. If it still gets hot, I'll add some heat sinks.
Actually, I totally forgot to say thanks for the CA3 front enclosure you send me a couple of weeks ago...
Sorry for that and Thank you!
