onloop said:Yes. I was talking about boosting voltage.
macribs said:I guess because he is so limited by space, as he was asking for his electric skateboard.
Not much room to change batteries to bigger pack, and probably also very limited range of motors that will fit into his skateboard regime.
And I can certainly see the need to up the voltage for such a specific application. For a bike it would be easier to just get the correct parts that meets your need - cause there is always room somewhere to add a little extra. But on a skateboard not so much.
O/T:
On a side note, if you got deep pockets or money left on your credit card and really need more fun in your life get the Baja Board. 4wd with 1 rc motor to each wheel, and air shocks. They say it is like snowboarding an endless descend.[youtube]slLHy4NlOvQ[/youtube]
liveforphysics said:Wind it as a single turn motor, perhaps HVH style bar-in-slot winding like the modern Remmy stuff used in the Volt and others.
Then the weak-link is no longer the motor, it is in finding a controller with the capability to drive it to it's potential. Make that controller, and you can stay in non-lethal voltage ranges, have your brutally delicious and extremely efficient low-RPM torque cake and eat your high RPM's power needs too.![]()
That was in the context of an air cored motor, though. With an iron core, eddy currents induced from any stray flux would be minimal. 'Skin effect' eddy currents, from the AC field, would be the same in either case, I think.Punx0r said:I was reminded of this thread after Miles recently commented on a motor design with a comment about the eddy current losses of the winding. If I understood it properly, it was that a large, solid copper wind would suffer very high losses. That was what made me think of this discussion involving single-turn windings.
Biff said:There are some smart gearboxes that have one fixed gear, and one reduced gear, such as the SMESH, which is just a planetary gear with a way to lock it into a 1:1. http://www.smesh.eu/ This would allow you to get lots of torque at low speed without sacrificing efficiency at high speed. It certainly adds complexity, and a bit of weight, but is pretty good.
Right. What value does the added mass bring compared to its equivalent in a larger motor? What are the drawbacks?liveforphysics said:If the mass of this mechanism were instead added in the form of a bigger radius of iron and copper to a direct drive motor, it would yield similar results, but in a way that improves continous power.
motomoto said:I know I am bringing up a 'controversial' subject, but it's not. Luke's obsession with copper and magnet weight always
being superior to the weight of steel gears is not correct. All the 'waste' of the extra weight and the drag of gears meshing
and bearing losses is nothing compared to the real waste. The waste of amps needed to do the job because of not having the proper gear ratio. That's it. The waste of amps needed to do the job because of the lack of having the proper gear ratio.
You're climbing a hill with your one speed Luke special and it takes 300 amps, or you could switch to the
proper gear and use only 50 amps to do the same thing. The waste is not having the proper gear and wasting your battery.
I am not saying Luke will not save us all by creating some miraculous battery technology because he probably will. I am just saying
that the physics in the real world of uphills and downhills and limited battery capacity, a proper gear change is negligible
and necessary.
motomoto said:I just wanted to get this off my chest.
You smart guys have an answer for everything.
motomoto said:I guess all your motors are at peak efficiency at all RPMs.
All the motors in the real world have an efficiency curve through the RPM band.
It's simple math to run the motor in the efficient area of the graph to not waste power. The drivetrain losses are minor. Losses from running
in poor performance RPM areas is many times greater.
Man, I don't know about you smart guys.
