I have four throttle wires on the controller: black, red, green and yellow. The throttle lever has three wires. I connected black to black, red to red and green to white. The yellow wire that goes from the controller is EBS + and I dont know where to conncet it. Where should I connect that wire?
The controller is 36V, EB306-A-3. I connected the hall and the phase wires to controller, but the engine does not rotate when I push the throttle. I've tried all 36 combinations of halls and phase wires but none of them works.
Does anybody can help mi with this?
A couple extra information about what I've been done/test so far. I tested the hall in a way that I turned the wheel and measured the voltage (it changes between 0 and 5V). I shorted the engine phases and then the rotation resistance was high for each combination. When I connect a hall, phases, throttle, and battery then I have a 5V voltage on a black and red throttle wires. I guess that all that tests are ok. The controller also has a red thin wire that I have connected to the red thick that goes to the battery.
