eDahon
I would like to purchase a Rc airplane motor (Turnigy Aerodrive SK3 - 6374-149kv Brushless Outrunner Motor) such as this one and make a friction drive.
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=18184
Add hall sensors: http://e0designs.com/prod/sensboard/sensclean.jpg
but cant figure out the best and most reliable way to drive it. I will need relatively low volatge (5s lipo) so can this work with a standard 24v (500-1000w)ebike controller? If I modified the LVC cutoff would it even work with a 5s lipo which is only about 18.5v. I realize the max current rating on the controller would have to be pretty high (say 60amps)
Would really like to use the car esc option but I question if it will work based on what i have read on here. I am most concerned about the braking. I don't know of any way of disabling the brake on a car esc such as this one:
http://www.hobbypartz.com/07e-c-xerun-150a-sd.html
anyone figure out a way of getting around the brake problem. A sensored airplane esc would probably work since these generally allow the brake to be disabled but sensored airplane esc are impossible to find these days.
